- Thank you received: 2
Problem with cursor Dynamic display
11 years 3 months ago #209009
by mehdikazemi
Replied by mehdikazemi on topic Problem with cursor Dynamic display
I have the same problem.
I cannot leave the maximum and minimum fields empty and price filter cannot set dynamically.
What should I do?
What should I do?
11 years 3 months ago #209018
by babaei
Replied by babaei on topic Problem with cursor Dynamic display
Hello
Extract attached file.
Go to administrator/components/com_hikashop/classes and replace extracted file with filter.php.
Before replacing make a backup of filter.php
The following user(s) said Thank You: mehdikazemi
11 years 3 months ago #209109
by Jerome
Replied by Jerome on topic Problem with cursor Dynamic display
@mehdikazemi : would it be possible to know which HikaShop version you're using ?
This thread is 4 months old and the file that babaei sent is for HikaShop 2.3.5 (when HikaShop 2.5.0 is the latest stable package).
So it might generate issues is you have a more recent version of HikaShop.
11 years 3 months ago #209158
by mehdikazemi
Thanks Mr. Babaei.
I replaced your file, but it couldn't solve the problem.
Jerome, I created new post for the issue, Thanks.
