- Thank you received: 4
No Products Found - Filter issue!
- srtdesigns
-- Joomla version -- : 3.8.5
-- PHP version -- : 7.1.14
-- Browser(s) name and version -- : Edge 41.16299.15.0
After many hours today I have given up. I have even done your tutorial example in your support document. What ever I try I keep getting No Products Found. Any advise would be much appreciated.
Would it be possible to have some details about what you have done and a link to your website product listing with the filter configured ?
Some information regarding the filter configuration would also be required to perform tests or understand the global behavior.
- srtdesigns
You can use our contact form:
Make sure you include a link to this thread.
Also, a screenshot of the filter and of the filter module (if you're using it) settings would be great so that we can better understand the situation.
- srtdesigns
I have sent an email as advised. The settings are attached to this topic. Two from the Filter Module and 1 from the Filter within the Shop Component. Many thanks.nicolas wrote: Hi,
In the "menu" setting of your module, you need to enter the id of a menu item of the type "products listing" which is configured to display all the products.
This is not done on your filter module and that's why it doesn't work.
Please do that.
- srtdesigns
I created a new Menu Item Hikashop > Product Listing which will show all products. I placed this in a Hidden Menu and the filter appears to work a treat. Thank you ever so much for your help, much appreciated.nicolas wrote: Hi,
Please do that.
