smart search does not work for variant product_codes
2 years 8 months ago #359560 by nico.van.leeuwen
-- Joomla version -- : 5.0.3
-- PHP version -- : 8.2.16
I have an up-to-date HikaShop site where we use variants with their own product_code.
Now the product_code of the main product is showing up in the search results but the ones from the variant is not.
Tried last HikaShop built, tested on multiple sites etc but no luck yet.
Hope you can reproduce it and that it's an easy fix :-)
Nico
2 years 8 months ago #359562 by nicolas
It works fine on my end.
Do you see the variant entries in the index of the smart search ?
Could you provide a screenshot of the settings of your HikaShop finder plugin via the Joomla plugins manager ?
2 years 8 months ago - 2 years 8 months ago #359576 by nico.van.leeuwen
I don't seem to find variants in the index.
Re-indexed it etc.
Sure, screenshot attatched.
Last edit: 2 years 8 months ago by nico.van.leeuwen. Reason: forgot something
2 years 8 months ago #359595 by nicolas
Thanks. I found the issue.
I've made a patch for it. Download again the HikaShop install package on our website and install it on yours to get the patch. Then, you need to reindex your products / variants and the product codes will be taken into account.
2 years 8 months ago #359641 by nico.van.leeuwen
I tried it with the updated version.
Re-indexed but no luck. I also don't see the result in the indexed products other than the main product.
I tried this on a develop site so no problem to give you access if you want.
2 years 8 months ago #359686 by nicolas
Yes, I'll need a backend and a FTP access. Please provide them via our contact form:
2 years 8 months ago - 2 years 8 months ago #359779 by nicolas
Thanks. I know what the problem is. When I tried to reproduce the issue on my end, I couldn't because I had other modifications included for the support of variants data, which are scheduled for the next version of HikaShop.
The current version of HikaShop actually doesn't support the indexing of variants data.
The indexing of the product_code specifically was another problem I found out but both the change I made previously following this thread, and the changes prepared on my end for the next version of HikaShop are necessary to be able to search a variants code.
Here is attached a modified installation zip of the finder plugin to be able to index variants which contains all the modifications.
Last edit: 2 years 8 months ago by nicolas.
The following user(s) said Thank You: nico.van.leeuwen
2 years 8 months ago #359785 by nico.van.leeuwen
Thanks you, this works great now.
2 years 7 months ago #359936 by mariussport
hi Nicolas and Nico,
The smart search works super fine now, but the variants doesn't show the standard product image, if there is not a specific variant image.
See the attachment.
best regards,
Marius
2 years 7 months ago - 2 years 7 months ago #359952 by nicolas
Thank you for your feedback. I've made some extra modifications in order to handle that properly. Here is the new zip for the finder plugin:
Last edit: 2 years 7 months ago by nicolas.
The following user(s) said Thank You: mariussport
