- Thank you received: 1
Option to view products and move the next and previous
5 years 9 months ago #329075
by ddevine
Option to view products and move the next and previous was created by ddevine
-- HikaAuction version -- : 3.0.1
-- Joomla version -- : 3.9.4
-- PHP version -- : 7.4.14
-- Browser(s) name and version -- : Chrome Version 88.0.4324.104
I need the Option to view products and move the next and previous.
Is there a way to add the next and previous buttons to individual products?
- Thank you received: 1778
5 years 9 months ago #329135
by Mohamed Thelji
Replied by Mohamed Thelji on topic Option to view products and move the next and previous
Sure, the option you want to use is "Show shortcuts to other category products" via "Hikashop->System->Configuration->Display".
Kind regards,
Mohamed.
Kind regards,
Mohamed.
5 years 9 months ago - 5 years 9 months ago #329164
by ddevine
Replied by ddevine on topic Option to view products and move the next and previous
That's great, although a little hard to see. Can I position it on the bottom of the page,
or make the icons larger and centered?
and/or under the Item image.
Also, I would like to use custom icons for the previous/next buttons
Great Product and has much potential.
Dennis
Dennis
Last edit: 5 years 9 months ago by ddevine.
5 years 9 months ago - 5 years 9 months ago #329251
by Mohamed Thelji
Hello Dennis,
Sure, using some CSS code will do the job :
www.hikashop.com/support/documentation/1...the-display.html#css
Also if you want to move previous/next buttons, the solution will be to directly edit the code of the "Show" file of the "Product" view of your front-end template via "Hikashop->Display->Views", and move these lines :
Kind regards,
Mohamed.
if(!empty($this->links->previous))
echo '<a title="'.JText::_('PREVIOUS_PRODUCT').'" href="'.$this->links->previous.'"><span class="hikashop_previous_product"></span></a>';
if(!empty($this->links->next))
echo '<a title="'.JText::_('NEXT_PRODUCT').'" href="'.$this->links->next.'"><span class="hikashop_next_product"></span></a>';
Kind regards,
Mohamed.
Last edit: 5 years 9 months ago by Mohamed Thelji.
5 years 9 months ago - 5 years 9 months ago #329405
by ddevine
Sorry, I can't find that. Could you send me the link to that in a generic website location?
Something like this?
Last edit: 5 years 9 months ago by Mohamed Thelji. Reason: Edited message for security purpose
5 years 9 months ago - 5 years 9 months ago #329446
by Mohamed Thelji
You'll find it via "Hikashop->Display->Views" by using the search filters like in the attached screenshot.
Kind regards,
Mohamed.
Kind regards,
Mohamed.
5 years 9 months ago #329473
by ddevine
Sorry, Several "show" listed
I did not see that one that was on the second page.
I believe I'll get a handle on this soon
Moderators: Mohamed Thelji
