- Thank you received: 9
How to place a Maximum Bid (or automatic maximum bidding)
8 months 4 weeks ago - 8 months 4 weeks ago #370597
by lucad
How to place a Maximum Bid (or automatic maximum bidding) was created by lucad
-- HikaShop version -- : 6.3.0
-- HikaAuction version -- : 5.0.1
-- Joomla version -- : 6
-- PHP version -- : 8.4
I guess this is not possible yet in Hikaauction, let me know if I am wrong please Team
On an auction, users should be able to enter a maximum bid and Hikaauction should treat it as a secret instruction. Hikaauction will only use as much of the maximum bid as necessary to make the highest bidder.
Let's say I am bidding on an auction with a starting price of €10, and the auction platform uses €1 bid increments.
I place my bid: I decide I am willing to pay up to €50. I enter €50 as your maximum bid.
The current price: Since nobody else has bid yet, Hikaauction places a bid on my behalf for the minimum amount required: €10.
I am now the highest bidder at €10 (even though my maximum bid is €50)
Another buyer comes along and bids €15.
Hikaauction immediately counters on my behalf, bidding €16 (the competitor's bid +1€ increment). I am winning again at €16 etc....
This automatic back-and-forth continues until the bidding surpasses my €50 limit. If a competitor bids €55, they become the highest bidder, and I am out of the running (unless I decide to submit a new, higher maximum bid)
Kindly let us know
Thank you
Kindly let us know
Thank you
Last edit: 8 months 4 weeks ago by lucad.
8 months 4 weeks ago #370598
Replied by nicolas on topic How to place a Maximum Bid (or automatic maximum bidding)
Actually, this is already possible with HikaAuction when using the Vickrey auction mode (which is the default mode).
In Vickrey mode, the system works exactly like eBay's automatic bidding:
- You enter your maximum bid amount (for example $50)
- The displayed "winning price" is only the second-highest bid + the bid increment, not your actual bid
- If someone bids $20 against your $50 maximum (with a $1 increment), you stay winning at $21 — the system automatically "counter-bids" for you
- You only get outbid if someone places a bid higher than your maximum
So using your example: if the starting price is $10 with a $1 increment and you bid $50, the winning price would show $10. If another user bids $15, the winning price would automatically go up to $16 and you'd still be winning. The other bidder would need to bid more than $50 to outbid you.
You can configure the auction mode in the HikaAuction configuration page (Components > HikaAuction > Configuration > Main tab > Auction mode). Make sure "Vickrey auctions" is selected.
The following user(s) said Thank You: lucad
8 months 4 weeks ago #370603
by lucad
Replied by lucad on topic How to place a Maximum Bid (or automatic maximum bidding)
That is absolutely great Nicolas, did not notice the Vickrey before!
But allow me to make 2 crucial points please:
1) very important: auctioneer should be aware of what kind of bid he is placing
see video: drive.google.com/file/d/1LBrdlczdpDJQHJj...ITd/view?usp=sharing
2) less important but still valid point: maximum bid should be kept hidden
see video: drive.google.com/file/d/1I3X0w1U0PQVycMg...vZT/view?usp=sharing
Thank you again for your support
8 months 4 weeks ago #370609
Well, you could turn off the display of the auction history in the settings of HikaAuction, that way, you would not leek the maximum bid.
But having an option to be able to display the auction history without the bid amounts could be added.
And regarding the first point, you can just add some text in a view override, or change some texts with translation overrides in order to make it clear to the user.
We'll look at improving this on our end.
Thanks again for all the feedback.
8 months 4 weeks ago #370614
by lucad
Thank you Nicolas, I am really happy I can help with feedbacks.
Removing the bidding history is not possible for transparency with the seller.. for example if the winner does not pay for an auction.. the seller needs to see the second best bid amount.
Also, changing some texts with translation overrides in order to make it clear is a good idea (see attachment)
but still needs a second box as the live bid needs to be free like in the video I sent before (this one: drive.google.com/file/d/1LBrdlczdpDJQHJje9_SkE7Lxl8y5XITd/view )
I am sure you guys will fix this too
Thank you again for your amazing support
8 months 4 weeks ago #370618
The next version will include two improvements that should address your needs:
1. A new "Hide bid amounts in history" option : When enabled, other bidders will only see that a bid was placed, not the actual amount. Each user can still see their own bid amounts. This keeps maximum bids secret while maintaining transparency for dispute resolution.
2. Better Vickrey mode communication : The bid input will now display "Your maximum bid (minimum: X)" instead of "Minimum bid: X", and an explanation text will appear below the bid form: "In this auction, you only pay the second-highest bid plus the bid increment, not your maximum. Enter the most you are willing to pay."
Regarding the idea of a second box (live bid vs. maximum bid): in Vickrey mode, every bid is already a maximum bid by design and the system automatically determines the winning price based on the second-highest bid plus the increment. So a second input field would be redundant since there's only one value to enter: the most you're willing to pay. The system handles the rest, exactly like proxy bidding on eBay.
With the hidden amounts and the clearer labeling, Vickrey mode will effectively work as a "secret max bid" system without needing any additional input fields.
8 months 4 weeks ago #370621
by lucad
Thank you Nicolas
1) 'Hide bid amounts in history' option: this is kind of hybrid bid (not a vickrey, not a sealed bid)
although it is not common kind of auction, they might be useful in certain situations.
I am sorry to insist, with all due respect, properly vickrey auctions with maximum bid should hide the maximum amount (or at least have an option to hide or not the maximum amount).
2) Yes, now that you have pointed that out, I totally agree with your assessment. Thank you for bringing it to attention
8 months 4 weeks ago #370626
Just to clarify: the "Winning price" displayed on the product page in Vickrey mode is already not the highest bidder's maximum. It shows the second-highest bid plus the bid increment, that's the core Vickrey principle. The actual maximum bid of the leading bidder is never shown on the product page.
So if bidder A places a max bid of €100 and bidder B bids €70 with a €5 increment, the winning price displayed will be €75 (second-highest + increment), not €100. Bidder A's real maximum remains hidden.
On top of that, the next version will add the option to also hide bid amounts in the auction history, so other bidders won't be able to see the individual amounts there either. Combined with the new explanation text on the bid form, users will understand they are placing a maximum bid and that the system handles the rest.
So I don't think we're missing anything for what we have planned for next version. Unless I'm missing something else ?
8 months 3 weeks ago #370629
by lucad
Bidder A's real maximum remains hidden and there will also be an option (show/hide) to hide bid amounts in the auction history
Yes, that's perfect
Thank you Nicolas!
Yes, that's perfect
Thank you Nicolas!
Moderators: Mohamed Thelji
