Related productsを移動したい
13 years 5 months ago - 13 years 5 months ago #110191
by mami
Related productsを移動したい was created by mami
2つ質問があります。
1: Related productsをshow_default.phpで記述されているエリア内に入れることは出来ますか。
2: JoomlaのModule Managerで新たに作成したRelated products(以後、新Related products)が商品詳細ページで表示されず、最初から入っていたRelated products(以後、旧Related products)は必ず表示されOFFに出来ません。具体的には、HikaShopのDefault設定と、該当するMenuの設定のどちらか、または両方の"Modules to display under the main area"で、新Related products選択しても旧Related productsしか表示されず、逆に、なにも選択していない(全てOFF)にもかかわらず、関連商品を設定してあるProductの詳細画面では、旧Related productsが必ず表示されます。解決方法はありますか。
よろしくお願いします。
よろしくお願いします。
Last edit: 13 years 5 months ago by mami.
13 years 5 months ago #110205
Replied by nicolas on topic Related productsを移動したい
You should not add your related products module in the "Modules to display under the main area" option of the configuration, but in the "Modules under the product page" option of the configuration as explained in the documentation:
www.hikashop.com/en/support/documentatio...ct-form.html#related
13 years 5 months ago - 13 years 5 months ago #110207
by mami
Replied by mami on topic Related productsを移動したい
Thanks, it works now. How about the first question?
13 years 5 months ago #110231
Inserting a module in descriptions can be done in several ways but it can pose some problems based on how you configure everything. So it's not possible to give a one size fit all solution.
For example, if you want to display add to cart buttons in your related products listing module, you will have to move the description display out of the form of the product page or the HTML elements will conflict and the add to cart buttons won't work properly.
The simplest solution though will be to use the joomla extension modules anywhere to insert a display tag for your related products module where you want in the description of each one your products.
13 years 5 months ago #110271
by mami
Okay, I understand what you mean. I may try by myself. Thanks anyway.
