- Thank you received: 1
Possible problem with session
- wideservices
12 years 5 months ago - 12 years 5 months ago #158364
by wideservices
Possible problem with session was created by wideservices
Something very strange occured. At my default configuration i have found out that i could not remove products from my cart. When i pressed the x(delete) button from the checkout at frontend, the product wasn't removed and the purchase was completed instead. I changed the joomla session handler from database to none and then the problem was fixed. Everything was fine for quite some time until now that no account can login. If i change the session handler back to database the login problem is fixed but the remove prouct problem comes back. Any suggestions? Thank you
*EDIT*
The remove product malfunction seems to happen if the user adds a product in cart and then he logs out. When he logs in again the produxt is in the cart and he can't remove it. If he ,however, adds another product in the cart then the remove button works!
*EDIT*
Last edit: 12 years 5 months ago by wideservices.
- Thank you received: 1778
12 years 5 months ago #158369
by Mohamed Thelji
Replied by Mohamed Thelji on topic Possible problem with session
Firstly can you download the last Hikashop version through our website, install it and test it again so that we can be sure that you're using the last Hikashop version ?
Also, can you give us a link to your shop so that we can directly test it ?
- wideservices
12 years 5 months ago #158539
by wideservices
Replied by wideservices on topic Possible problem with session
You have the latest stable version of HikaShop Business: 2.3.1 (i have updated it recently)
url: moodleshop.wideservices.gr/en
Thank you
Thank you
12 years 5 months ago #158545
by Mohamed Thelji
That's maybe coming from a cache issue so can you disable the Joomla cache, and clear it ? You'll also have to disable it in the joomla config, and unpublish the cache plugin. Also can you clear your browser's cache and try it again ?
- wideservices
12 years 5 months ago #158697
by wideservices
Hi ,
Cache was disabled in the global configuration, the system cache plugin was unpublished and i have tried it in different browsers with their cache cleared. The same thing happens.
12 years 5 months ago #158707
by Xavier
Replied by Xavier on topic Possible problem with session
There is a strange thing with your cart module, it is not always displayed the same way.
Don't you have a conflict at this point, many cart modules ?
- wideservices
12 years 5 months ago #158910
by wideservices
I had two cart modules in different positions . Now I am using only 1 cart module . The one in the top right corner. I have tried to disable it too, but the same problem occurs.
12 years 5 months ago #158970
by nokki00
Replied by nokki00 on topic Possible problem with session
HikaShop this is a bug. When ever the cart has something in it for a long period of time and when you come back to clear the cart it will not clear.
When I try to clear the cart it refreshes to website.com/product/listing and it doesn't clear the cart.
When I add some thing to the cart then try to delete it works and refreshes to http://website/checkout/step/step-1 so I can delete the other products.
Then I try to delete the last item in the cart it deletes it works and returns to website.com/product/listing
www.hikashop.com/forum/checkout/868584-c...-empty-checkout.html
-- url of the page with the problem -- : local
-- Joomla version -- : 3.3
-- PHP version -- : 5.3.24
12 years 5 months ago #159023
by Xavier
This problem seems to be the same than the one here:
hikashop.com/forum/checkout/868584-canno...checkout.html#159016
So lets continue on one topic only
