Create Related Products column in Administrator
- jnascimento
11 years 11 months ago #174300
by jnascimento
Create Related Products column in Administrator was created by jnascimento
I'm trying to change the Administrator products listing to show the related products link in the list. (image in attachment
So far i was able to add the Title by adding the <td> on the right place.
My difficulty now is that i cannot get the related products title in the fields.
I enter this code in the product/listing.php file:
<td align="center">
<?php if($this->manage){ ?>
<a href="<?php echo hikashop_completeLink('product&task=edit&cid[]='.$row->product_related_id); ?>">
<?php } ?>
<?php echo $row->product_name; ?>
</a>
<?php } ?>
</td>
But what i get is only the same product name...
Can you please tell me what can i do to make this possible?
<td align="center">
<?php } ?>
</a>
<?php } ?>
</td>
11 years 11 months ago - 11 years 11 months ago #174342
by Jerome
Replied by Jerome on topic Create Related Products column in Administrator
Doing such modification require some development/PHP skills.
You have to perform an SQL query in order to get the related products for the products you will list.
For the moment the code display the product name of the current product in the loop ; but if you do not have loaded the related products, you won't be able to display them.
$query = 'SELECT a.*,b.* FROM '.hikashop_table('product_related').' AS a LEFT JOIN '.hikashop_table('product').' AS b ON a.product_related_id=b.product_id WHERE a.product_related_type=\'related\' AND a.product_id = '.$row->product_id;
$database->setQuery($query);
$related_products = $database->loadObjectList();
Last edit: 11 years 11 months ago by Jerome.
- jnascimento
11 years 11 months ago #174472
by jnascimento
Replied by jnascimento on topic Create Related Products column in Administrator
Thanks for the reply.
I'm sorry i'm still "very young" on PHP coding.
I'm trying to apply this to the code but i'm not having results with it.
Im doing this:
I'm calling the product_name after requesting the query but it's not working.
Can you help with this little bit of code?
Im doing this:
<td>
<?php
</td>
- Thank you received: 1778
11 years 11 months ago - 11 years 11 months ago #174511
by Mohamed Thelji
Replied by Mohamed Thelji on topic Create Related Products column in Administrator
The code that Jerome gave you will just allow you to load the related products details on the "$related_products" object, now you'll just have to check what you have on that object and display the link of your related products.
Using that kind of code will probably do the job :
$database = JFactory::getDBO();
foreach($related_products as $key => $related_product){
if(!empty($related_product)){
<a href="<?php echo hikashop_completeLink('product&task=edit&cid[]='.$related_product->product_id); ?>">
<?php
echo $related_product->product_name.'</br>';
</a><?php
Last edit: 11 years 11 months ago by Mohamed Thelji.
- jnascimento
11 years 11 months ago #174566
by jnascimento
Thanks for the reply... i try it under the <td></td> and it didn't work... i'm getting a blank page...
- jnascimento
11 years 11 months ago #174623
by jnascimento
IT's working now...
This is what i have done:
Many thanks for your support!
Best Regards,
<td>
<?php
<?php
</a>
<?php
</td>
Best Regards,
11 years 11 months ago #174639
by Jerome
Good to know that it is working now.
When you got full blank page, do not hesitate to check your PHP error log or to activate the Joomla debug mode (in the joomla global configuration).
You can also change the "error reporting" to "maxium" in the Joomla global configuration (server).
Time to create page: 0.176 seconds
