How to refresh a module with ajax based on checkout shipping method?
5 years 7 months ago - 5 years 7 months ago #331120 by oxido
-- HikaShop version -- : 4.4.1
-- Joomla version -- : 3.9.25
I have create a module which is taking his details from the cart.
I configurated this module to be visible in Hikashop Checkout, using the text view, by adding this tag to load the module.
{module id="116:Hikashop Custom Module" showtitle="false"}
And now, i need the module to refresh himself when the shipping method is changed, how can I do this?
Please give me as many details, javascript it's not my strong point.
Loading the module in checkout
Visible in Front-page
Last edit: 5 years 7 months ago by oxido. Reason: I have attached the module.
5 years 7 months ago #331146 by nicolas
Well, a simple solution would be to add the code of your module directly in one of the view files which is refreshed when the shipping method is changed.
For example, you have the "status" view which just displays the selected shipping and payment methods. If you don't use it, you could repurpose it with your own code to display your custom content on the checkout and the show_block_status where you would add your code already has the javascript code to refresh itself when the shipping method is changed:
<script type="text/javascript"> if(!window.checkout) window.checkout = {}; window.Oby.registerAjax(['checkout.shipping.updated','checkout.payment.updated'], function(params){ window.checkout.refreshStatus(<?php echo (int)$this->step; ?>, <?php echo (int)$this->module_position; ?>); }); window.checkout.refreshStatus = function(step, id) { return window.checkout.refreshBlock('status', step, id); }; </script>
Now if you want to stick to your solution with the loadposition in the "text" view, you would need to add such similar javascript to the show_block_text view file via the menu Display>Views.
The following user(s) said Thank You: oxido
5 years 5 months ago #332041 by oxido
For future me and others:
edit the view: checkout / show_block_status.php
// Create a position for module: checkout-position // prepare content to be rendered corectly with "content.prepare". echo JHtml::_('content.prepare', '{loadposition checkout-position}');
Now you can set any module to be visible to this position, and it will be refreshed by ajax.
PS. Thx nicolas!
Time to create page: 0.143 seconds
