Hikashop User Points - calculation problem
10 years 11 months ago - 10 years 11 months ago #222133 by stephanie.pomerleau
-- HikaShop version -- : 2.6.0 Business
-- Joomla version -- : 3.4.1
I am having an issue with how points are being earned on purchase.
I want points to be earned as 1 point for 1$ on specific categories only.
When the plugin is configured to earn 1 point for each dollar, with no product category specified (see: Capture-user-point-plugin-config-01.jpg), everything works as expected. 3 admissible products in the cart for a total of $49.50 earns 50 points (see: Capture-points-no-category-in-config.jpg)
When I add a product category in the "Product categories" field in the configuration (see: Capture-user-point-plugin-config-02.jpg) , the points earned are more than the rate that has been set. 49.50$ earns 83 points, but should only earn 50. (see: Capture-points-with-category-in-config-02.jpg)
With same configuration settings as previous (with product categories), when I have 2 different products, but in the same category, points are ok. $33 earns 33 points (see: Capture-points-with-category-in-config-02A.jpg)
If I have 2 identical products, points are multiplied, and actually earn more than 1 point per 1$. $33 earns 66 points (see: Capture-points-with-category-in-config-02B.jpg)
The problem is amplified when I put 9 identical items in the cart. 148.50$ earns 1337 points. (see: Capture-points-with-category-in-config-9-identical-products.jpg).
If I test using 1 product in the desired category, and 1 product outside the desired category (deos not earn points), the behaviour is as expected: points on the coffee, but not on the tea. $33 dollars, but only 16.50$ is admissible to points, and 17 points are earned. (see: Capture-points-with-category-in-config-1-product-not-in-category.jpg)
It looks like the points are calculated by multiplying the number of products by the subtotal of the product line (9 x 148.50$ = 1336.50 points, which rounds to 1337).
I don't think this is the expected behaviour, and this should be fixed.
Thanks,
Stephanie
Last edit: 10 years 11 months ago by Jerome. Reason: insert capture in message in order to be able to analyze it
10 years 11 months ago #222143 by Jerome
Thanks for that detailed report.
In the plugin, when you have a filter on the product categories, the plugin will check each product and process the sum for all of them which are in the targeted categories :
$product_price = 0.0; if(empty($product->prices) && !empty($product->order_product_price)) { $product_price = (float)hikashop_toFloat(@$product->order_product_price) + (float)hikashop_toFloat(@$product->order_product_tax); } else if(!empty($product->prices)) { if(isset($product->prices[0]->price_value_with_tax)) $product_price = $product->prices[0]->price_value_with_tax; else $product_price = $product->prices[0]->price_value; } if(isset($product->order_product_quantity)) $product_price *= (int)$product->order_product_quantity; else $product_price *= (int)$product->cart_product_quantity;
In that algorithm, we want to get the unit price of the product ; but it looks like in your case it retrieve the global price.
So we will add few lines in order to force the reading of the unit price.
$product_price = 0.0; if(empty($product->prices) && !empty($product->order_product_price)) { $product_price = (float)hikashop_toFloat(@$product->order_product_price) + (float)hikashop_toFloat(@$product->order_product_tax); } else if(!empty($product->prices)) { $p = $product->prices[0]; if(isset($p->unit_price)) $p = $p->unit_price; if(isset($p->price_value_with_tax)) $product_price = $p->price_value_with_tax; else $product_price = $p->price_value; } if(isset($product->order_product_quantity)) $product_price *= (int)$product->order_product_quantity; else $product_price *= (int)$product->cart_product_quantity;
Let me know if it fixes your issue.
Kind regards,
The following user(s) said Thank You: stephanie.pomerleau
10 years 11 months ago - 10 years 11 months ago #222262 by stephanie.pomerleau
And where do I find the file that has this code that I need to change? Sorry, I am new at HikaShop :)
UPDATE: found the file: plugins/hikashop/userpoints/userpoints.php
Last edit: 10 years 11 months ago by stephanie.pomerleau. Reason: update info
10 years 11 months ago #222264 by stephanie.pomerleau
Your code fixed the problem, thank you!!
