Product with custom fields - insertion in article
-- PHP version -- : 2.6.1
I have a product with custom fields that I would like to access directly through product insertion in article. When calling the article with insertion there is a need to press "choose options" button to go to the product page and I'd need to access this page directly.
I've attached prints of the first page and second page (the second is the one that I'd like to appear in article).
Thank you
Please make sure that the "Display custom item fields" setting of the HikaShop configuration is activated.
Could you also advice on how to show original uploaded image instead of thumbnail?
Now, a custom filed of Date type is also not working anymore. Some suggestion?
1. Change the line:
echo '<img class="hikashop_product_tag_image" title="'.$this->escape(@$image->file_description).'" alt="'.$this->escape(@$image->file_name).'" src="'.$img->url.'"/>';
echo '<img class="hikashop_product_tag_image" title="'.$this->escape(@$image->file_description).'" alt="'.$this->escape(@$image->file_name).'" src="'.$img->origin_url.'"/>';
in the file plugins/system/hikashopproductinsert/hikashopproductinsert_view.php and remove the CSS width:200px; from it and that should do it.
2. Change it to the type "advanced date picker".
I suppose that you should have some javascript issues in your page.
The "advanced date picker" is using jQuery and jQuery UI to work ; if you have javascript issues, the initialization of the date picker might not be done correctly.
I installed Jquery easy to see if I can discover where the problem is but with no success. Do you have some suggestion?
What can I do?
Can you please restore your template and provide us a link to the page ?
You only provide your domain name but we do not know the page with the issue.
Because we can't see the issue, we can't provide you any precise answer.
bemvindoaisrael.com/index.php/servicos/8...-massada-e-mar-morto
Thanks,
Please try to add the code:
Ok, let's try differently.
Change the code:
