- Thank you received: 13
Custom Invoice problems
- mohairbears
11 years 11 months ago #179737
by mohairbears
Custom Invoice problems was created by mohairbears
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.4.24
-- Browser(s) name and version -- : Firefox 33.0.3
Hi, I am trying to customise the invoice and would like to move the 'shipping address' to where the 'Billing address' currently is, I have tried to do this in order/invoice and managed to do this BUT when I change anything in this file it will then not print? is this the correct file to amend?
I have bought the PDF plugin and cannot get that to work as it produces this error
Fatal error: Call to undefined function mb_strlen() in /home/mohairbe/public_html/plugins/hikashop/attachinvoice/attachinvoice.php on line 292
11 years 11 months ago #179750
by Jerome
Replied by Jerome on topic Custom Invoice problems
The invoice PDF plugin use PHP Multibyte function in order to support UTF8 languages.
php.net/manual/en/function.mb-strlen.php
You have to be sure that your server handle the multibyte functions ; it is maybe a module to activate in your PHP server configuration.
For your printing error ; I am sorry but I don't understand the issue. Without a look to your page it is difficult to see what could be the problem.
- mohairbears
11 years 11 months ago #179831
by mohairbears
Replied by mohairbears on topic Custom Invoice problems
Hi, PDF solved now thanks.
Where the shipping address & the invoice is placed on the invoice I need to swap their positions as I use a peel off invoice paper so the shipping address appears on the left of the invoice instead of the right.
Is there a way to alter the PDF invoice as the order number appears on there very large? plus the above would need to be changed?
thanks
thanks
11 years 11 months ago #179852
Replied by nicolas on topic Custom Invoice problems
Sure.
You can edit the file plugins/hikashop/attachinvoice/attachinvoice/invoice.php and change the code in it.
Swapping the addresses is easy.
Just change the line:
$addresses = array('billing_address','shipping_address');
$addresses = array('shipping_address','billing_address');
- mohairbears
11 years 10 months ago #180107
by mohairbears
Thanks Nic...
One more then I think I have this sorted.
Is it possible to increase the white space between the 2 address boxes?
thanks
thanks
11 years 10 months ago #180115
by Xavier
Replied by Xavier on topic Custom Invoice problems
I think that you can add a "<td>" between the two addresses, so add:
After:
Or add css properties at the top of the file in the <style> area.
<td class="my_class"></td>
<td valign="top">
<fieldset>
<legend><?php echo JText::_('HIKASHOP_'.strtoupper($oneAddress)); ?></legend>
<?php
if(!empty($order->$oneAddress->address_company)) echo $order->$oneAddress->address_company.'<br/>';
echo $order->$oneAddress->address_title.' '.$order->$oneAddress->address_firstname.' '.$order->$oneAddress->address_lastname.'<br/>';
echo $order->$oneAddress->address_street.'<br/>';
echo $order->$oneAddress->address_post_code.' '.$order->$oneAddress->address_city.' '.$order->$oneAddress->address_state.'<br/>';
echo $order->$oneAddress->address_country.'<br/>';
if(!empty($order->$oneAddress->address_telephone)) echo JText::sprintf('TELEPHONE_IN_ADDRESS',$order->$oneAddress->address_telephone).'<br/>';
if(!empty($order->$oneAddress->address_vat)) echo JText::_('VAT_NUMBER').' : '.$order->$oneAddress->address_vat.'<br/>';
</fieldset>
</td>
- mohairbears
11 years 10 months ago #182964
by mohairbears
11 years 10 months ago #182982
by Xavier
In the invoice.php file, you can potentially add a max-width property on the div displaying these instructions.
- mohairbears
11 years 10 months ago - 11 years 10 months ago #183087
by mohairbears
Hi, Cannot find a div that refers to this?
I have sort of solved it using .hikashop_order_custom_fields_fieldset td{width: 250px;} but this leaves the text mid page and increasing/decreasing the px either moves it across the page or narrows the text box itself? below is what I have but I would like to remove the white space.
Another problem I have is when no VAT is charged a minus (-) sign is in from of the £, see below.
Last edit: 11 years 10 months ago by mohairbears.
11 years 10 months ago - 11 years 10 months ago #183233
Try with such CSS instead:
.hikashop_order_custom_fields_fieldset td{width: 450px;}
.hikashop_order_custom_fields_fieldset td.class{width: 120px;}
And for the taxes, instead of:
if($taxes != 0){
change that code to:
if($taxes > 0){
in the invoice.php file.
if($taxes != 0){
if($taxes > 0){
Last edit: 11 years 10 months ago by nicolas.
Time to create page: 0.236 seconds
