Product Description not shown in Product listing
12 years 10 months ago #140506 by Marsipulami
www.bodystuff.ch/danii/index.php/hikasho...for-products-listing
-- HikaShop version -- : Hika Starter 2.3.3
-- Joomla version -- : 3.2.1
-- PHP version -- : 5.3.23
Hi there
I am testing the hika shop with my new page. So far i'm very happy with it but there are some problems i couldn't get right. Here is my first one :)
Is is possible to show a little product desciption in the product listing?
I've turned the switch on for the descrition but nothting is shown.
Am i doing anything wrong?
Thanks for help
Marsipulami
You have to be patient with me :P
12 years 10 months ago #140523 by Mohamed Thelji
I think that you'll probably find your answer through this thread
12 years 10 months ago - 12 years 10 months ago #140529 by Marsipulami
Thanks for your answer
I tried the solution explained in this other thread.
But i couldn't find the code echo $this->row->product_name in the listing_table file of my template.
So i couln't put the new code after that line.
What am i doing wrong?
Is this the right file to change?
product / listing_table.php from my template (rt_lumiere)
Greets
Marsipulami
Last edit: 12 years 10 months ago by Marsipulami.
12 years 10 months ago #140546 by Mohamed Thelji
My bad the solution was this answer :
You'll have to add this code :
<td class="hikashop_product_description_row"> <?php echo $this->row->product_description; ?> </td>
after this :
<?php if ($this->config->get('show_code')){ ?> <td class="hikashop_product_code_row"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_code; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </td> <?php } ?>
and add this code :
<th class="hikashop_product_description_title" align="center"> <?php echo JText::_( 'PRODUCT_DESCRIPTION' ); ?> </th>
after this :
<?php if ($this->config->get('show_code')) { $columns++;?> <th class="hikashop_product_code_title" align="center"> <?php echo JText::_( 'PRODUCT_CODE' ); ?> </th> <?php } ?>
12 years 10 months ago - 12 years 10 months ago #140549 by Marsipulami
Hi Mohamed
Thank you.
So far the description work.
But the problem is, that i only want the text before the mark "read more" is that possible?
The Idee is that in the product table, is only a short descrition of the product.
But in the product detail page, there will be more descrition for the linked product.
Best wishes
Marsipulami
12 years 10 months ago - 12 years 10 months ago #140552 by Mohamed Thelji
Ok, so the best solution will probably to edit the code :
By :
<td class="hikashop_product_description_row"> <?php if(strlen($this->row->product_description )> NB_CHAR) echo substr($this->row->product_description, 0, NB_CHAR); else echo $this->row->product_description; ?> </td>
Note that you'll have to replace the "NB_CHAR" word by the length of your category description.
Last edit: 12 years 10 months ago by Mohamed Thelji.
12 years 10 months ago #140557 by Marsipulami
There must be an error in your code Mohamed
Parse error: syntax error, unexpected ';' in line 144
12 years 10 months ago #140558 by Marsipulami
ok found the error...was the point after nb_char)
but it doesn't cut the description with the number of char
12 years 10 months ago #140560 by Mohamed Thelji
My bad, here is the code to use :
The following user(s) said Thank You: Marsipulami
12 years 10 months ago - 12 years 10 months ago #140564 by Marsipulami
Damn...
Mohamed you're my man :)
Many thanks....it looks great like this.
That is a product listing, like it have to be ;)
