Insert custom fields in table display products
12 years 2 months ago #170504
by gioxd
Insert custom fields in table display products was created by gioxd
www.laputea.com
-- Joomla version -- : 3.2
I would like to insert custom fields in the table to display the products, but do not know how you do it. I tried to put this code <?php echo $this->row->NAME_FIELD; ?> in product / listing_img.php
But in front end I see only the number (the value) and not the name of the field. How do I display the name of the custom field?
Thank You!
Thank You!
12 years 2 months ago #170506
by Xavier
Replied by Xavier on topic Insert custom fields in table display products
You can use this code:
<?php echo 'Name Field: '.$this->row->NAME_FIELD; ?>
12 years 2 months ago #172798
by gioxd
Replied by gioxd on topic Insert custom fields in table display products
Sorry, don't work. I insert the code, maybe we can find a solution
<?php
* @version 2.3.2
* @author hikashop.com
* @copyright (C) 2010-2014 HIKARI SOFTWARE. All rights reserved.
* @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html
?><?php
$link = hikashop_contentLink('product&task=show&cid='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway,$this->row);
if(!empty($this->row->extraData->top)) { echo implode("\r\n",$this->row->extraData->top); }
<!-- PRODUCT IMG -->
<div style="height:<?php echo $this->image->main_thumbnail_y;?>px;text-align:center;clear:both;" class="hikashop_product_image">
<div style="position:relative;text-align:center;clear:both;width:<?php echo $this->image->main_thumbnail_x;?>px;margin: auto;" class="hikashop_product_image_subdiv">
<?php if($this->params->get('link_to_product_page',1)){ ?>
<a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>">
<?php }
$image_options = array('default' => true,'forcesize'=>$this->config->get('image_force_size',true),'scale'=>$this->config->get('image_scale_mode','inside'));
$img = $this->image->getThumbnail(@$this->row->file_path, array('width' => $this->image->main_thumbnail_x, 'height' => $this->image->main_thumbnail_y), $image_options);
if($img->success) {
echo '<img class="hikashop_product_listing_image" title="'.$this->escape(@$this->row->file_description).'" alt="'.$this->escape(@$this->row->file_name).'" src="'.$img->url.'"/>';
$main_thumb_x = $this->image->main_thumbnail_x;
$main_thumb_y = $this->image->main_thumbnail_y;
$horizontal = '0';
$vertical = '0';
if($this->params->get('display_badges',1)){
$this->classbadge->placeBadges($this->image, $this->row->badges, $vertical, $horizontal);
$this->image->main_thumbnail_x = $main_thumb_x;
$this->image->main_thumbnail_y = $main_thumb_y;
</a>
<?php } ?>
</div>
</div>
<!-- EO PRODUCT IMG -->
<!-- PRODUCT PRICE -->
<?php
if($this->params->get('show_price','-1')=='-1'){
$config =& hikashop_config();
$this->params->set('show_price',$config->get('show_price'));
if($this->params->get('show_price')){
echo $this->loadTemplate();
<!-- EO PRODUCT PRICE -->
<!-- PRODUCT VOTE -->
<?php
if($this->params->get('show_vote_product')){
$this->setLayout('listing_vote');
<!-- EO PRODUCT VOTE -->
<!-- PRODUCT CUSTOM -->
<?php echo 'materialeprincipale: '.$this->row->materialeprincipale; ?>
<!-- EO PRODUCT CUSTOM -->
<!-- ADD TO CART BUTTON AREA -->
<?php
if($this->params->get('add_to_cart') || $this->params->get('add_to_wishlist')){
?><form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->row->product_id.'_'.$this->params->get('main_div_name'); ?>"><?php
$this->ajax='';
if(!$this->config->get('ajax_add_to_cart',0)){
$this->ajax = 'return hikashopModifyQuantity(\''.$this->row->product_id.'\',field,1,\'hikashop_product_form_'.$this->row->product_id.'_'.$this->params->get('main_div_name').'\',\'cart\');';
$this->setLayout('quantity');
if(!empty($this->ajax) && $this->config->get('redirect_url_after_add_cart','stay_if_cart')=='ask_user'){ ?>
<input type="hidden" name="popup" value="1"/>
<?php } ?>
<input type="hidden" name="product_id" value="<?php echo $this->row->product_id; ?>" />
<input type="hidden" name="add" value="1"/>
<input type="hidden" name="ctrl" value="product"/>
<input type="hidden" name="task" value="updatecart"/>
<input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url)));?>"/>
</form><?php
<!-- EO ADD TO CART BUTTON AREA -->
<!-- COMPARISON AREA -->
<?php
if(JRequest::getVar('hikashop_front_end_main',0) && JRequest::getVar('task')=='listing' && $this->params->get('show_compare')) { ?>
<br/><?php
if( $this->params->get('show_compare') == 1 ) {
$js = 'setToCompareList('.$this->row->product_id.',\''.$this->escape($this->row->product_name).'\',this); return false;';
echo $this->cart->displayButton(JText::_('ADD_TO_COMPARE_LIST'),'compare',$this->params,$link,$js,'',0,1,'hikashop_compare_button');
} else { ?>
<input type="checkbox" class="hikashop_compare_checkbox" id="hikashop_listing_chk_<?php echo $this->row->product_id;?>" onchange="setToCompareList(<?php echo $this->row->product_id;?>,'<?php echo $this->escape($this->row->product_name); ?>',this);"><label for="hikashop_listing_chk_<?php echo $this->row->product_id;?>"><?php echo JText::_('ADD_TO_COMPARE_LIST'); ?></label>
<?php }
<!-- EO COMPARISON AREA -->
<?php if(!empty($this->row->extraData->bottom)) { echo implode("\r\n",$this->row->extraData->bottom); } ?>
12 years 2 months ago #172837
by Xavier
I checked the code and that should work.
It's not in a if condition, so it must be displayed somewhere, unless you edited the view in the wrong template, or you have cache enabled.
12 years 2 months ago #173033
by gioxd
Ok, it work. But i visualize the number of field custom, not the name.
Is possible see the custom field name and not the value?
12 years 2 months ago #173048
by Xavier
Is that coming from a dropdown ?
I had not understood your real need.
You have to use the code:
Where you have to replace "32" by the id of you custom field, you can find it via the Display > Custom fields menu in the backend.
<?php
$fieldclass = hikashop_get('class.field');
$myField = $fieldclass->get('32');
echo $myField->field_value['3']->value;
12 years 2 months ago #173278
by gioxd
12 years 1 month ago #173282
by Xavier
I tested the code on my end and it was working fine, thanks to try this code:
<?php
$myField = $fieldclass->get('19');
if(isset($this->row->materialeprincipale))
echo $myField->field_value[$this->row->materialeprincipale]->value;
The following user(s) said Thank You: gioxd
12 years 1 month ago #173418
by gioxd
Perfect! Now it work!
Thank You!
Thank You!
