Problem with Comments Systems
12 years 2 weeks ago #178850 by ricardo
-- Joomla version -- : 3.3.6
Hi, I have a problerm with the comments system. If I try to write the comment and auto publish system it's activated it's all ok, but if I deactivate the auto publish I can't moderate the comments via backend.
Thanks a lot...
Ricardo.
12 years 2 weeks ago #178857 by Jerome
Why can't you moderate the comments via backend ?
12 years 2 weeks ago #179047 by ricardo
Why? I don't knwow... if I try to check Pubblish I receive an error but don't show me wath's this error...
12 years 2 weeks ago #179050 by Jerome
Okay, so you can "see" them but not publish them.
Would it be possible to have more details in general and more details about the error thanks to your PHP error log ?
Or maybe by setting the "error reporting" to "maximum" in your Joomla global configuration.
12 years 2 weeks ago #179115 by ricardo
Hi Jerome,
I need this error in for position of the database:
id select_type table type possible_keys key key_len ref rows Extra
1 SIMPLE chew_hikashop_product system PRIMARY NON E' POSSIBILE UTILIZZARE ALCUN INDICE NULL NULL 1
But I don't find the parameter "Full" for the debug... Where I find the PHP error log?
Thanks...
12 years 2 weeks ago #179120 by ricardo
If would you like I can give you an access to the backend...
12 years 2 weeks ago #179148 by Jerome
Yes I think it will be easier to understand the situation.
Please use the "contact us" form and provide a link to that forum thread.
12 years 2 weeks ago - 12 years 1 week ago #179333 by Xavier
Please edit the file "administrator/components/com_hikashop/classes/vote.php" and in the function "saveBackend()" replace:
if(empty($element->vote_ref_id)) $element->vote_type = $db_vote->vote_ref_id;
By:
if(empty($element->vote_ref_id)) $element->vote_ref_id = $db_vote->vote_ref_id;
Thanks for the report, we have corrected that on our end.
Last edit: 12 years 1 week ago by Xavier. Reason: change code order
12 years 1 week ago #179522 by ricardo
Hi, I'm sorry, but the problem persist...
12 years 1 week ago #179530 by a2zcs
Replied by a2zcs on topic Problem with Comments Systems
Maybe I'm confused. My vote.php file had:
and it didn't work.
Replaced it with:
and it does now.
12 years 1 week ago #179531 by ricardo
Ok, don't worry!!
Now it's solved!
Thanks a lot!!
Bye!!
12 years 1 week ago #179568 by Xavier
Yes, sorry you had to reverse the two codes, I have corrected my last topic.
Time to create page: 0.095 seconds
