how to make a product grid view
10 years 2 months ago - 10 years 2 months ago #248616 by ronron
Great the bracket worked but its always a list or single column.
the other links such as http://...store?columns=2 and
http://...h/store?columns=3 doesnt work
also nic
i hope its ok,can you please remove my website link on your reply posts just for security reasons.
thanks a lot
Last edit: 10 years 2 months ago by ronron.
10 years 2 months ago #248609 by Jerome
Not at the end of the file ; just at the end of the added line :
if(!@$_GET['columns'] || $_GET['columns']>3){ $_GET['columns'] = 1;
The following user(s) said Thank You: ronron
10 years 2 months ago #248724 by ronron
thank you its working
unfortunately all modules are affected by this. So my horizontal carousel slides are all single column.
maybe we should add the override in a different view?
thanks again
10 years 2 months ago #248733 by Mohamed Thelji
In that case the solution will be to use that PHP condition to check if we are in a module or not :
//If we are on a product listing module if($this->module){ }
10 years 2 months ago - 10 years 2 months ago #248856 by ronron
hi
how do i complete this?
//If we are on a product listing module if($this->module){ null;} else { <?php if(!@$_GET['columns'] || $_GET['columns']>3){ $_GET['columns'] = 1; $this->params->set('columns', $_GET['columns']); ?> <a href="http://mayari.com.ph/store">1 column</a> <a href="http://mayari.com.ph/store?columns=2">2 columns</a> <a href="http://mayari.com.ph/store?columns=3">3 columns</a> }
its not working. thanks
Last edit: 10 years 2 months ago by Jerome. Reason: [code] is nice
10 years 2 months ago #248872 by Jerome
When you write some code in the forum ; please use the "code" tag.
I am afraid that "it is not working" is not clear enough to understand what is not working exactly.
Now regarding your code, I can see a missing closing bracket.
If you want to learn PHP ; I suggest you to look for websites specialized in that domain.
10 years 2 months ago - 10 years 2 months ago #248934 by ronron
thanks jerome
let me explain. i got the code below to work but my carousel modules are all in a list or single column because of code below.
//code for grid view altering columns <?php if(!@$_GET['columns'] || $_GET['columns']>3){ $_GET['columns'] = 1; $this->params->set('columns', $_GET['columns']); ?> <a href="http://mayari.com.ph/store">1 column</a> <a href="http://mayari.com.ph/store?columns=2">2 columns</a> <a href="http://mayari.com.ph/store?columns=3">3 columns</a> }
mohammed thejii gave me the code below but i dont know how to use it.
hi and thank you Mohamed Thelji
what should i do with this please?
10 years 2 months ago #248935 by nicolas
As Jerome said, you're missing a bracket. The code should be:
//If we are on a product listing module if($this->module){ null;} else { <?php if(!@$_GET['columns'] || $_GET['columns']>3){ $_GET['columns'] = 1; $this->params->set('columns', $_GET['columns']); ?> <a href="http://mayari.com.ph/store">1 column</a> <a href="http://mayari.com.ph/store?columns=2">2 columns</a> <a href="http://mayari.com.ph/store?columns=3">3 columns</a> <?php } }
And also as Jerome said, this is basic PHP coding. Please contact professional developers to help you with such customization if you can't do it yourself.
10 years 2 months ago - 10 years 2 months ago #249258 by ronron
thanks Nic
i got this to work.
my next issue are the filters.
i created a sort filter, price range filter, search filter and others. all of these filters are not working together. example i searched for rings on the text search. if i click on sort the results reset or re-set. So instead of narrowing the results down it restarts. Its like its back to the original setting of the individual filters.
i also tried disabling force redirect on the module. the filters still doesnt respond accordingly.
this is the link. Please try to search for anything in the text search and try using the filters. the text you typed will be erased or reset.
thanks again
10 years 1 month ago #249274 by nicolas
The issue is that your text search filter is in a different module than the sort filter. And each filter module is independent from one another.
You could try to turn on the "redirect POST mode" setting of the HikaShop configuration. It might help. But the best would be to have only one filter module with all the filters.
10 years 1 month ago - 10 years 1 month ago #249877 by ronron
hi
1.i would like to know please how come on small screens particularly Tablet portrait (768x1024) and below the columns wont separate in two or three columns. i think its because of the bootstrap. Can you point me where to fix this?
2. i would like my layout to change from img and description for single columns to image and title view for 3 or more columns, 2ould it be correct to add this small code as a solution.
also where to add this?
if ($_SERVER['mysite.com/single-column'] !== 'mysite.com/single-column') { call image and title layout }
thanks
thanks
Last edit: 10 years 1 month ago by ronron.
10 years 1 month ago - 10 years 1 month ago #249888 by nicolas
1. Bootstrap CSS handles the switch from several columns to 3, but there is no intermediate.
It would require adding custom CSS to handle that such as:
@media (max-width: 1100px and min-width: 768px) .col-sm-4 { width: 50% !important; }
2. You can use such code:
$this->params->set('div_item_layout_type','img_title');
Last edit: 10 years 1 month ago by nicolas.
Time to create page: 0.123 seconds
