- Thank you received: 22
Custom field link problem
-- Joomla version -- : 3.7.8
-- PHP version -- : 7.1
We need a cutom field link on some products (not all). So I set custom field link. All works fine, but cant find a way to have empty field. So if admin not enter url and text, then field is not showing on product detail.
I try to delete default value in custom field, but allways : is showing.
You're right the classic way to proceed is to display a field only if the value isn't empty, that's the better way to proceed for most of HikaShop user, sorry if that's don't fit your specific needs.
Anyway, I have 2 solutions to suggest :
- Create another custom field (with the same Label) for all other product that don't need your url link.
- Then, use some some custom Css, to only hide this custom field value, see my screenshot to better understand my idea :
For product configuration page :
image missing https://cdn.pbrd.co/images/Hl8JOQ9.png
Then the custom Css to only remove the custom field value (and not the label)
image missing https://cdn.pbrd.co/images/Hl8JOaO.png
See this tutorial to see how to add Css command
The other solution is to realize a custom code of HikaShop Custom field process to display (only this field) even if empty, you can do it yourself or ask for one of partner
Hope this will answer your questions.
You say "You're right the classic way to proceed is to display a field only if the value isn't empty."
This is the right way. And your link custom field not working that way. So there is a bug and maybe you should solve it?
There are other problems to.
If I fill value for link field and want to delete it over time, there is label on product with no value.
Sorry for my bad english
- Thank you received: 1778
Can you give us more information about your issue but also about what you exactly want to achieve through some screenshots ?
Thank you.
Custom field works, but with bug. To reproduce, you can try:
- create custom field link
- check on product detail - OK
- delete value of custom field link
- check on product detail - empty field still there
Second bug
- enter default value and save
- try to delete default value - you cant
The result is: custom field link allways shows, empty or not.
Text field for example shows when something is writen in field. When you delete that value, field not showing on frontend. That is right behavior.
I see. Add the code:
Thank you.
Which problem, the first or second bug you reported here ?
We did some modifications in the code of the link type custom fields with the latest version of HikaShop as it didn't handle correctly empty values.
So if I enter link and save, then delete link and save, link is still on product page, but only slash.
Ok, I think I see what you mean.
I've added a patch on our end.
Please download again the install package on our website and install it on yours and it will add the patch for that.
Please note that you'll have to save the product once to see the change if the custom field is already empty but displaying on the product details page.
