error 404 on infinite scroll product listing after uptdate to 4.1
7 years 4 months ago #307735 by Bender
-- url of the page with the problem -- : aketo.kz
-- HikaShop version -- : 4.1.0
-- Joomla version -- : 3.9.5
-- PHP version -- : 7
-- Error-message(debug-mod must be tuned on) -- : /index.php?option=com_hikashop&ctrl=product&task=listing&cid=1534&limitstart=48&Itemid=1971&tmpl=raw:1 Failed to load resource: the server responded with a status of 404 ()
If to unpublish category and to enable infinit scroll feature
it began show category not found
aketo.kz/irz/routers/r0
in previous versions it was ok
how to fix ?
7 years 4 months ago #307743 by nicolas
Thank you for your feedback.
This only happens because the category is actually selected as main category of the menu item. Otherwise, you don't see the category on the listings and thus its normal you can't access it.
The issue is that the infinite scroll system shouldn't pass the cid parameter in the URL if the category being displayed is the one selected in the main category setting of the menu item. That should solve the problem.
I've added a patch on our end for that. Download the install package on our website and install it on yours and that should fix that problem.
7 years 4 months ago #307772 by Bender
7 years 3 months ago #308403 by Bender
I noticed that only 48 products were displayed on the page, despite the fact that the infinite scrolling is enabled. Previously, this was not. In the product settings, I have a 4x12 grid. But in some categories I have more than 120 products, but only the first 48 are displayed. How to check? Here is one of the pages aketo.kz/datchiki/beskontaktnye/inductive (4x12 grid) , aketo.kz/iek-group/category/iek-indicators (4х3 grid)
If you change the grid, it will only display the first page. I wanted to see the logs, but did not find anything unusual there.
7 years 3 months ago #308406 by nicolas
Download again the install package on our website and install it on yours and that should help.
7 years 3 months ago - 7 years 3 months ago #308416 by Bender
nicolas wrote: Hi,
i installed new package, but in first page it still do not work
in second it began to work ?
in the first case there is a Joomla menu for the category, in the second there isn’t, can it affect the patch?
p.s. it is, if through the menu to make a category, it does not work.
Last edit: 7 years 3 months ago by Bender.
7 years 3 months ago #308421 by nicolas
All this comes from the fact that we've added some checks so that it's possible to access unpublished categories via the parameters in the URL. It's now only possible to access an unpublished category if it's selected as main category of a menu item.
This created some issues with the infinite scroll system as it was passing the id of the category via the URL instead of letting the server side get it from the current menu item. So we made a patch to allow for that.
On my end, when I test on my test website, it works fine with the latest patch.
If you still have an issue on some listings, I'm afraid we'll need a backend and FTP access to the website in order to analyse the situation and modify the patch as we might be missing a specifc case.
Please provide that along with a link to this website via our contact form:
7 years 3 months ago #308460 by Bender
7 years 3 months ago #308488 by nicolas
I've added a patch on your website which seems to fix the issue.
Please check your website and report if you find any issue or if it's all good.
We'll add the patch to the next release if it's all good.
7 years 3 months ago - 7 years 3 months ago #308504 by Bender
nicolas wrote: Hi,
scrolling began to work in the place where it did not work, but now it works incorrectly, after loading the goods, it loads goods from other categories of which it should not.
An example can be seen here.
aketo.kz/owen/regulyatory/trm1
there is a 4x12 grid and only 21 products in the category, but when the page is scrolls, it starts loading products from other categories.
and if there are more products than 48 in the category and the grid size is 4x12, then when loading the following products it does not display the remaining products from the categories, but again displays the products from other categories, see here
aketo.kz/datchiki/temperatury/termosoprotivleniya
As you can see after scroll the same product are loaded in different categories
7 years 3 months ago #308528 by Bender
I got the difference:
If the joomla menu type is product listing your patch works, but if joomla meny type is category listing patch not work correct it will
display firtst page and after scroll next page load the products from wrong categories
7 years 3 months ago #308536 by nicolas
Thanks for the details, that helped a lot.
The patch was missing a bit to make sure that the current menu item was a category listing or a product listing.
I've added a second patch and it seems to be all good now on your different links. Let me know.
7 years 3 months ago #308546 by Bender
Thank you very much. Now it works fine.
7 years 2 months ago - 7 years 2 months ago #309616 by Bender
nicolas wrote: Hi,
the same error ocurre again on my hikashop if joomla menu type is hikashop category listing .
Did you included both patches in 421 update (for product listing and for category listing ) ?
Only product listing works
aketo.kz/iek-group/asynchronous-motors/air-im1081 this url is category listing - not works (show only first of 48 products from category)
aketo.kz/iek-group/asynchronous-motors/air-im2081 this url is product listing category - works
Last edit: 7 years 2 months ago by Bender.
7 years 2 months ago #309626 by nicolas
Yes, both patchs are included. So it must come from something else. I'm afraid we'll have to debug again on your website. Could you provide accesses again ?
7 years 2 months ago #309757 by Bender
nicolas wrote: Hi,
sure. i sent you email with theme "error 404 on infinite scroll product listing after uptdate to 4.1"
7 years 2 months ago #309787 by nicolas
I got the email. I'll try to look at the issue during the week if I have time but I might have to postpone that as I'm currently in holidays and will be back next week. Sorry for the delay in advance.
7 years 2 months ago #309973 by Bender
nicolas wrote: Hi,
ok. awaiting.
7 years 2 months ago #310046 by nicolas
I'm back to it.
I wanted to look into it just now but I couldn't connect to your FTP server:
Status: Connecting to 185.120.78.239:21... Status: Connection attempt failed with "ECONNREFUSED - Connection refused by server". Error: Could not connect to server
Could you check that we can connect to it ?
7 years 1 month ago #310489 by Bender
21 port is closed on server, please use 22 port instead
