Display# on products listing
3 years 1 month ago - 3 years 1 month ago #355230 by Petike1007
-- HikaShop version -- : 4.7.4
-- Joomla version -- : 4.3.3
I'm using the Categories listing table layout menu item (not sure it matters or not) and I would like to display 10 items on one page. So i set the row number to 10.
But the default values are in the Display# field are 40-80-120-160-200-all
How can I chnge it to 10-20-30-40-50-all?
Last edit: 3 years 1 month ago by Petike1007.
3 years 1 month ago #355231 by nicolas
It should be already like that by default.
Can you provide a screenshot of the settings under the products options tab of your menu item and the URL of the page ?
3 years 1 month ago - 3 years 1 month ago #355242 by Petike1007
It's on localhost under development.
See attached front and back images.
At the moment I set in a template override with the $this->params->set('limit',10);
For sure it's somewhere set in hikashop to 40, but I can't see anywhere the number 40 in settings.
3 years 1 month ago #355246 by nicolas
I think I know what's going on.
There is a problem with the javascript not updating the number of elements of the listing when changing between the different layouts (div, table, etc). You need to manually click on the number of rows you want and then save to have it saved in the database, so that it can be taken into account on the frontend.
I've made a patch for this on our end.
If you update, you'll then have the number of elements refreshed when changing the layout in the backend, and thus it will be taken into account when saving.
The following user(s) said Thank You: Petike1007
3 years 1 month ago #355252 by Petike1007
Correct...that was the issue...thanks
