- Thank you received: 14290
Issue ith canonical URLs
3 years 3 weeks ago #355856
Replied by nicolas on topic Issue ith canonical URLs
Then I'm not sure what the change should be. It would require some debugging of the Language Filter plugin.
3 years 3 weeks ago #355894
by Sandra74
Replied by Sandra74 on topic Issue ith canonical URLs
There's something that is confusing to me.
The canonical URLs work fine for one collection and not for the others. I can't understand why it's not consistent.
For the moment, as a temporary solution I disabled the "alternate" feature in the language filter plugin to have the canonical URLs displayed in the source code.
3 years 3 weeks ago #355909
by Sandra74
Me again.
I have another site in 2 languages and on this one no problem, canonical URLs work and alternate URL too. So it should be something within the site which prevents things to work as expected
Sandra
Sandra
3 years 2 weeks ago #356073
by Sandra74
I just noticed another issue with canonical URLs.
Even with Add Alternate Meta Tags on NO, the canonical URLs are not correct.
In the default language (US), it's ok, but not in French, the canonical URL remains the same as you can see for example on this page:
rolex.jewelrygoldfinger.com/fr/collection/yacht-master
The canonical URL should contain "fr" but it doesn"t. In fact it displays the canonical URL set up on the main screen and not the one set up in the French screen,
I'm really not sure it's an issue with the plugin.
I really need to be able to solve this issue but I have no clue how.
Thanks in advance for your help.
Sandra
Sandra
3 years 2 weeks ago #356086
Indeed, I can see the translation of the canonical URL is ignored. I've made a patch which should fix the problem.
Download again the install package of the 5.0.0 and install it on your website and you'll get the patch.
3 years 2 weeks ago #356088
by Sandra74
Thanks a lot Nicolas. It works, 'fr' is now in the canonical URL.
I also noticed something (no clue if it can be of any help):
- Add Alternate Meta Tags on YES
- Remove URL Language Code on NO
For the default language (US), it's all good, canonical + alternate
In the second language (so here French), canonical is missing
Sandra
Sandra
3 years 2 weeks ago #356093
Isn't that the same problem we were talking about since the beginning of this thread ?
3 years 1 week ago #356133
by Sandra74
Yes, it's part of the problem.
3 years 1 week ago #356138
Well, if you can provide a backend and a FTP access, I can have a deeper look into it and maybe try to understand what can be done to fix the problem. If we provide a correct patch to the Joomla project, they'll be more reactive and integrate it in Joomla.
3 years 1 week ago #356146
by Sandra74
With pleasure!
3 years 1 week ago #356157
I think I found the solution.
Adding the line:
before the line:
in the file /plugins/system/languagefilter/src/Extension/LanguageFilter.php seems to do the job.
Adding the line:
if($i !== $this->current_lang)
$doc->addHeadLink($server . $language->link, 'alternate', 'rel', ['hreflang' => $i]);
3 years 1 week ago #356181
by Sandra74
You rock!
It works like a charm.
Thank you so much!
Sandra
You rock!
Thank you so much!
Sandra
Time to create page: 0.108 seconds
