TaxCloud Error on Products w/Characteristics
12 years 5 months ago - 12 years 5 months ago #157779 by jazzmang
-- url of the page with the problem -- : new.littleapplewoodenpuzzles.com/handmad...em/wooden-stool.html
-- HikaShop version -- : 2.3.1
-- Joomla version -- : 3.3.0
-- PHP version -- : 5.4.27
-- Browser(s) name and version -- : Any
-- Error-message(debug-mod must be tuned on) -- : TaxCloud error : (see attached)
I just added a Characteristic to a products (simple "Colors" with 2 choices) and now I get a generic "TaxCloud: error" any after an address/login is entered during checkout. It just starts appearing any where on the site that com_hikashop is displayed.
I've tried even the default ProtoStar template and it gives me the same error. I find nothing in the web server logs.
I checked to make sure that the variant items and they do have the Product Taxability Code set.
I tried add just an Option to the original product (without any Characteristics) and there was no issue. So this appears to be specific to something with Characteristics. I tried adding price to the variant (just to see) and no help.
All other products work fine and if I remove the Colors Characteristic, the product is fine.
Not sure exactly what it could be.
I upgraded to 2.3.1 on my internal test server and it has the same issue if I add a Characteristic.
Last edit: 12 years 5 months ago by jazzmang. Reason: Add additional info
12 years 5 months ago #158050 by Mohamed Thelji
Firstly can you show me some screenshots of how did you configured the "Hikashop TaxCloud Plugin" ?
12 years 5 months ago #158086 by jazzmang
See attached.
Remember, TaxCloud works perfectly when there is no characteristics.
12 years 5 months ago #158087 by jazzmang
Note that my test server is a completely different Linux build and physical server in a different network/location than production.
The test server is a fresh install of Joomla with no other extensions besides Hikashop.
The test server also uses a different TaxCloud account than the production site so it isn't not TaxCloud account specific.
I have tried this without the custom name fields on the product too. The result is the same error.
12 years 5 months ago #158402 by Mohamed Thelji
Can you edit the "\plugins\hikashop\taxcloud\taxcloud.php" file, and change these lines :
$cart_items[] = array( 'Index' => $i, 'ItemID' => $product->product_code, 'TIC' => $tic, 'Price' => $product->prices[0]->unit_price->price_value, 'Qty' => $product->cart_product_quantity );
By :
if($product->product_type == 'variant') $price = $product->prices[0]->unit_price->price_value; else $price = $product->prices[0]->price_value; $cart_items[] = array( 'Index' => $i, 'ItemID' => $product->product_code, 'TIC' => $tic, 'Price' => $price, 'Qty' => $product->cart_product_quantity );
The following user(s) said Thank You: jazzmang
12 years 5 months ago #158473 by jazzmang
That appears to fixed it. My quick tests show it is working.
Thank you!
12 years 4 months ago #159632 by kevin@solasus.com
I've applied the above fix and it's not working. Perhaps the issue on my side is that we have multiple characteristics
product w/ no characteristics is fine: ownthenight.aurorastudios.tv/shop/produc...or-2010-ach-arc-rail
product with multiple is not: ownthenight.aurorastudios.tv/shop/produc...-helmet#.U5cY8pRdWVM
we also have complex products (custom) - which pulls in a variety of different options (some w/ multiple characteristics): ownthenight.aurorastudios.tv/helmets/custom-helmets
Note our nexus is NY
Thoughts...?
Thank you!
-kb
12 years 4 months ago #159637 by jazzmang
You might wan to pull the patched version (with another fix in it as well) from this thread:
www.hikashop.com/forum/taxes/868807-taxc...celed-restarted.html
I made a mistake the first time I tried the patch in this tread however.
There are several arrays in the taxcloud.php that look similar so you have to be careful.
Also I found another bug on Sunday which now has a patch as well:
www.hikashop.com/forum/taxes/868855-taxc...s-errors.html#159580
My recommendation is to get the .zip file that Nicolas posted and try it first.
Then try patching the second thread patch after that.
12 years 4 months ago #159640 by kevin@solasus.com
Thanks for the quick reply...
I've tried the zip. However still seeing the errors.
In server logs there's a PHP Notice: Trying to get property of non-object in /home/ownthenight/public_html/plugins/hikashop/taxcloud/taxcloud.php on line 1075
ln 1075 is: "$price = $product->prices[0]->unit_price->price_value;" in
12 years 4 months ago #159649 by jazzmang
To try and replicate your issue, I added another characteristics to a product one of our sites that was having the issue (before the patch).
The item had two characteristics but I don't have any problems (no tax cloud errors) during checkout.
I didn't try anything fancy, say with price changes on the variants or adding in options with characteristics.
My guess is it more than just simply multiple characteristics but some other combination within.
Sorry I don't have time to help isolate it further for a few days but that I what I would try isolating (the exact combination) for HikaShop support.
12 years 4 months ago #159747 by yeso
I also tried to add multiple characteristics but i didn't get the error. What you can try is to replace this line
By this one
if(isset($product->prices[0]->unit_price->price_value))
12 years 4 months ago #159782 by kevin@solasus.com
Hi yeso - that did make a small change, but I went from two errors to one... then somehow back to 2, just be refreshing.
That said I've echo'd the $cart_items array on the cart page to see what the differences might be.
a) Working product
ownthenight.aurorastudios.tv/shop/produc...-helmet-liner-system
Array ( [0] => Array ( [Index] => -1 [ItemID] => tic_rate_0 [TIC] => 0 [Price] => 1 [Qty] => 1 ) [1] => Array ( [Index] => 1 [ItemID] => Team_Wendy_REVOLVE [TIC] => 0 [Price] => 99.00000 [Qty] => 0 ) [2] => Array ( [Index] => 2 [ItemID] => Team_Wendy_REVOLVE [TIC] => 0 [Price] => 99.00000 [Qty] => 0 ) [3] => Array ( [Index] => 3 [ItemID] => Team_Wendy_REVOLVE [TIC] => 0 [Price] => 99.00000 [Qty] => 0 ) [4] => Array ( [Index] => 4 [ItemID] => Team_Wendy_REVOLVE [TIC] => 0 [Price] => 99.00000 [Qty] => 0 ) [5] => Array ( [Index] => 5 [ItemID] => Team_Wendy_REVOLVE_Helmet_Liner_System_20_17 [TIC] => 0 [Price] => 99 [Qty] => 1 ) ) Array ( [0] => Array ( [Index] => -1 [ItemID] => tic_rate_0 [TIC] => 0 [Price] => 1 [Qty] => 1 ) [1] => Array ( [Index] => 1 [ItemID] => Team_Wendy_REVOLVE [TIC] => 0 [Price] => 99.00000 [Qty] => 0 ) [2] => Array ( [Index] => 2 [ItemID] => Team_Wendy_REVOLVE [TIC] => 0 [Price] => 99.00000 [Qty] => 0 ) [3] => Array ( [Index] => 3 [ItemID] => Team_Wendy_REVOLVE [TIC] => 0 [Price] => 99.00000 [Qty] => 0 ) [4] => Array ( [Index] => 4 [ItemID] => Team_Wendy_REVOLVE [TIC] => 0 [Price] => 99.00000 [Qty] => 0 ) [5] => Array ( [Index] => 5 [ItemID] => Team_Wendy_REVOLVE_Helmet_Liner_System_20_17 [TIC] => 0 [Price] => 99 [Qty] => 1 ) )
b) Error-ing product
ownthenight.aurorastudios.tv/shop/produc...ach-ballistic-helmet
Array ( [0] => Array ( [Index] => -1 [ItemID] => tic_rate_0 [TIC] => 0 [Price] => 1 [Qty] => 1 ) [1] => Array ( [Index] => 1 [ItemID] => Size [TIC] => 0 [Price] => [Qty] => 0 ) [2] => Array ( [Index] => 2 [ItemID] => TBHII__ [TIC] => 0 [Price] => 415 [Qty] => 1 ) [3] => Array ( [Index] => 3 [ItemID] => Color [TIC] => 0 [Price] => [Qty] => 0 ) [4] => Array ( [Index] => 4 [ItemID] => Color_9 [TIC] => 0 [Price] => [Qty] => 1 ) [5] => Array ( [Index] => 5 [ItemID] => Size_16 [TIC] => 0 [Price] => [Qty] => 1 ) ) Array ( [0] => Array ( [Index] => -1 [ItemID] => tic_rate_0 [TIC] => 0 [Price] => 1 [Qty] => 1 ) [1] => Array ( [Index] => 1 [ItemID] => Size [TIC] => 0 [Price] => [Qty] => 0 ) [2] => Array ( [Index] => 2 [ItemID] => TBHII__ [TIC] => 0 [Price] => 415 [Qty] => 1 ) [3] => Array ( [Index] => 3 [ItemID] => Color [TIC] => 0 [Price] => [Qty] => 0 ) [4] => Array ( [Index] => 4 [ItemID] => Color_9 [TIC] => 0 [Price] => [Qty] => 1 ) [5] => Array ( [Index] => 5 [ItemID] => Size_16 [TIC] => 0 [Price] => [Qty] => 1 ) )
The only thing that I can think of here is that the working product does not have value that changes the price - even though a "price change" value was NOT selected in the non-working product. I also tried to get the working product to break by adding 2 characteristics and also making some variants different prices. Also tried adding options to the working product and could not break by that either.
any thoughts..?
12 years 4 months ago #159784 by kevin@solasus.com
Looking at these arrays side by side - I think I see the problem. In the "broken" one several prices are missing.
after the if/else statement I've added (around ln 1075)
if (!$price) $price = '0';
Don't know if I'm missing out on calculating some values here though... but at least the error messages are gone...
12 years 4 months ago #159797 by nicolas
From what I can see the notice message comes from the fact that there are no prices for one of the products/variants/options in the cart.
It's just a small check missing. Your fix will do but we'll do something a bit more involved for next version to make sure that this doesn't happen.
Another easy solution to avoid that is to turn off the "error reporting" option of the Joomla configuration.
Time to create page: 0.123 seconds
