- Thank you received: 92
product quantity and serial quantity
10 years 1 month ago #252189
by lionel75
product quantity and serial quantity was created by lionel75
-- HikaShop version -- : 2.7
-- HikaSerial version -- : 1.10.4
-- Joomla version -- : 3.4
-- PHP version -- : 5.4
I i have a package ( call it package1) with many serial and want a product ( call it product1) .
in each whe nedit product1 i set product quantity to 1 and the serial to 1 ( see the capture screen ) .
which parameter i have to change to be able to have in product quantity =1 and serial Qty = 1
Regard's
Attachment not found
Regard's
10 years 4 weeks ago #252192
by Jerome
You have a pack (because the name is HikaSerial is pack) link to your product with a ratio 1:1.
So when 1 product will be bought, HikaSerial will assign 1 serial to the user.
There is nothing more complicated than that.
Replied by Jerome on topic product quantity and serial quantity
10 years 4 weeks ago - 10 years 4 weeks ago #252303
by lionel75
Replied by lionel75 on topic product quantity and serial quantity
Hi , nothing is logic or easy for me so i need to read explicit information and more example .
to stay focus on my quetions
When in product1 i configure quantity=1 and in same time in serial quantity =1. when save and re-edit the produt1; i see that the 1 is converted to unlimited ( in the gui for product quantity not serial ) . so hikashop don't let me store the value 1 i choose or convert the value 1 to unlimited !!!
so how ca n i be shure that hikashop don't change my value 1 to something else after save ?
To focus on your response
If in serial panel the value quantity is 2 for pack1 Does it mean when end user buy 1 product he ll have 2 serials ?
Thank's
Thank's
Last edit: 10 years 4 weeks ago by lionel75.
10 years 4 weeks ago #252348
by Jerome
I recommend you to take a look at the HikaSerial setting "Link product quantity"
www.hikashop.com/support/documentation/1...ink_product_quantity
Thank you for asking a clear question !When in product1 i configure quantity=1 and in same time in serial quantity =1. when save and re-edit the produt1; i see that the 1 is converted to unlimited
