Mobile problem
3 years 9 months ago #348591 by khashiz
Mobile problem was created by khashiz
-- HikaShop version -- : 4.7
-- HikaSerial version -- : 4.0.2
-- Joomla version -- : 4.2.6
-- PHP version -- : 8.1
I have an strange problem with serialcosume on mobile
i have a consume menu in this address :
ozhangasht.com/ticket
when i want to consume a serial, it works fine in computer, but if i open this pge in a mobile device and enter the serial code, it gives error "serial not valid"
whty is it for ?
3 years 9 months ago #348633 by khashiz
Replied by khashiz on topic Mobile problem
this is a serial with the status of "assigned" : 882188
this is another serial with the status of "assigned" : 271884
and this is my consume link: ozhangasht.com/ticket
try one of them in pc and ot will be consumed
try another in mobile, and it gives error that serial is invalid !!!
3 years 9 months ago #348644 by Jerome
Replied by Jerome on topic Mobile problem
Your smartphone application is opening the URL while scanning ; so the serial is already consume when you open it via your browser.
You have to check your application settings to be sure that it does not load the page.
You can also use the setting "Forbidden consume for guests" so your smartphone application won't be able to perform the action because it doesn't have the required session
www.hikashop.com/support/documentation/1...ration.html#main_adv
3 years 9 months ago #348646 by khashiz
Why you are swipping the problem under the carpet ???
I test it with 3 different phones
And i’m not using any strange app
Its the app default camera and browser
Besides, scanning what ?!!!
I enter the url manually in the browser and the promlem is still there
And if it is what you are saying, why the serial status is still “assigned” ??
3 years 9 months ago #348648 by Jerome
Okay.
Can you please provide screenshots of your HikaSerial "serial" configuration ?
3 years 9 months ago #348665 by khashiz
I attached two files :
- screenshot of my main configuration page
- screenshot of one the serials configuration
3 years 9 months ago #348666 by khashiz
the most strange thing is that consuming works in desktop ! not working in mobile devvices even when i enter the consume URL manually in browser's address bar
3 years 9 months ago #348694 by Jerome
Are you authenticated with your desktop browser ?
Your test serial is related to a specific user ; which mean that it might be only available for consumption for that specific user.
What is your pack configuration ? Do you have some "consuming" plugin enabled/configured ?
3 years 9 months ago #348696 by khashiz
In both desktop and mobile browsers i checked the system as guest.
i can not understanf your questions ... if the problem comes from what you say, it must NOT work anywhere, not desktop, nor mobile but the system is working in desktop
3 years 9 months ago #348697 by khashiz
I my self think its a bug in code, if you think problem is from settings, i would really appriciate your help if it is possible that i send you an admin user in my website so you can check it.
i'm a new user of hikaserial, it is possible that i have mistakes in configuration
our business is in danger due to this issue
3 years 9 months ago #348698 by khashiz
what is the name of plugin i have check to be activated ?
3 years 9 months ago #348699 by Jerome
HikaSerial is a Joomla component ; it does not have any knowledge of the "remote" device and have one single workflow for consumption.
Only global setting, pack settings and "consumer" plugins can affect that workflow and define its rules (if guest are allowed, if a linked serial can be consume, etc).
You can say it's a bug in the code and I can answer you that there is no one single line of code which will change the behavior of HikaSerial if you're using a desktop or smartphone browser.
But the cookies and the session can be different regarding Joomla and the other plugins you have installed (like a cookie consent).
Even if you're browser as a guest ; the form submission is using a Joomla token, which requires a session.
Without cookies, you don't have a session and you can't consume a serial (even with guest).
It's one of many possibilities.
And if you can provide the screenshot and the other elements I asked you previously, I would be able to confirm some other thoughts.
Your account in our website does not own an HIkaSerial licence and your website is not link to an HikaSerial subscription.
If you want to send us admin access (via the contact us form only) ; please also indicates your subscription licence so we can link your website with it.
3 years 9 months ago #348770 by khashiz
I have finally fixed the problem.
it was about "shared session" option in joomla settings
in desktop because i was signed in my admin panel, system shared my session to other tabs and considered me as a signed in user so the hikaserial form showed the result, but in mobile iwas a guest user and system gived invalid serial
