attach serial to product
12 years 2 months ago - 12 years 1 month ago #169482 by lionel75
-- HikaSerial version -- : 1.8.3
-- Joomla version -- : 2.5.22
-- PHP version -- : 5.3.9
-- Browser(s) name and version -- : many many
hi
A serial is a key and is manage using package. so package associate key and product items
1) what is the relation beetween package ( one group of key ) and MANY differents products ?
2) How many way exist for grouping products ? does any of this groups of products can be manage by hikaserial package ? I think of variant and category group for products ; is there anothers one ?
3) for example i have many differents products that have in common the same category name .
i want to attach a different serials for all this products ?I think there is many way to attach a serial for each products ...but is there a easy logicial way to achieve this if many ways exist ?
4) Is there constraint if serial are generate/attach after buy compare when serial are attach by default in each products i nthe setting of product ?
5) how joomla know that is must must manage serial for a product if product don't have any predefine key but only information that key must be compute generate and attach/send to buyer when the product is in the card and payment is effective ?
6) after product creation is there a way to attach 1 serial of a package to 1 product in stock ( automatic way ) ? i have 200 products that share the same category name value and need to attach for each product a ( predefine unique) serial that are in one package (that contain 200 serial)
Can i have some information about the best way to achieve this ?
7) Is there schema workflow for hikaserial ?
is there a schema available that show workflow/timeline with how key are generate and consume attach use free ....... ( the logic/ worflow behind pack ( key =serial )
Here a schema that i try to create to better undertsand hikaserial ( start / begin not finish ) ?
a-i don't use a standart way even i know there is some standart way to render worflow the information
b- i could add php code begug instruction in some joomla file to view the workflow but no hikaserial worflow has been set /configure .
regard's
Last edit: 12 years 1 month ago by lionel75.
12 years 2 months ago #169494 by Jerome
Replied by Jerome on topic attach serial to product
It depends on what kind of predefined unique serial you have to provide.
The timeline is explained in the HikaSerial presentation, under the section "what is a serial" :
www.hikashop.com/support/documentation/1...tml#what-is-a-serial
The classical workflow is describe in the main HikaSerial tutorial :
www.hikashop.com/support/documentation/2...serial-tutorial.html
The HikaSerial import will allow you to import the serials and the packs.
The following user(s) said Thank You: lionel75
12 years 2 months ago - 12 years 2 months ago #169495 by lionel75
Replied by lionel75 on topic attach serial to product
Thank's i ll take time to read the documentation and test .
To summarize all my questions ; my question shoud be :
is there a way to apply a pack to a group of product that share some fields value in common .
for example products that have/share a commomn category value ?
By use apply , i mean an easy ( automatic) way to manage this instead create a package of one key for each products ?
regard's
Last edit: 12 years 2 months ago by lionel75.
12 years 2 months ago #169498 by Jerome
Like I said, it depends on what kind of predefined unique serial you have to provide.
You edited your message while I wrote my message...
You can use the same pack for every product and set a quantity of "1".
But I really depends on what kind of predefined unique serial you want to provide.
12 years 2 months ago #169556 by Jerome
Please understand that we do not provide support using private message.
I only read private message for accesses or private message, not for support.
So please answer to my question (that I asked you twice) if you want help us to help you.
Otherwise, I won't be able to give you a better answer that I have already did.
