A few questions for HikaMarket
13 years 1 month ago #126613 by southga1974
-- url of the page with the problem -- : the-authors-club.com
-- HikaShop version -- : 2
-- Joomla version -- : 3.15
-- PHP version -- : 5.3.27
-- Browser(s) name and version -- : Internet Explorer 9
I need help setting up some things. First of all, vendors:
1. I can't get photos to upload for the vendors. I see the upload bar, but the pictures won't upload.
2. How do I control what fields new vendors see when they sign up? I've turned off some of the fields in the display tab, but I still see them when I try to register some of my existing members. Is there a way to turn existing members into vendors automatically?
3. How do I create or add a Product template? I click on the Add button in that tab, but nothing happens.
4. What is Main Vendor? Is that me/my store? Do I need to add a PayPal email address? I already have HikaShop set up to use my PayPal email address.
13 years 1 month ago #126619 by Jerome
1 - Please check that your HikaShop upload folder have write permission.
HikaMarket create folders for your vendors in this directory, it will upload the images in these.
2 - It depends on which field you want to hide.
We added new display options in custom fields, HikaMarket have several display categories and in the next release, we will add a separation between the "register" and the "edition" page.
3 - I can't reproduce your problem in my local (joomla 3) website. Which precise versions number of HikaShop and HikaMarket are your using ?
The "add" button should redirect you to a HikaShop product edition where you can configure the values for the product template.
4 - The main vendor is your store. You do not require to specify the paypal email, this field is used by the plugin "paypal adaptive" but the email used for the main vendor is specify in the plugin configuration itself.
The following user(s) said Thank You: southga1974
13 years 1 month ago #126626 by southga1974
I'm getting things to work in Firefox, but not Internet Explorer. One more question, is it possible to add the Variants to the product template?
13 years 1 month ago #126629 by Jerome
Internet Explorer does not have the support of the drag&drop that's why the upload library have a fallback system for these cases.
For the variants on product template ; Well, I never test it so I can't guarantee it.
I have update my TODO list so I will check it and make some modification if required.
13 years 1 month ago #126721 by southga1974
I have one more question: is it possible to set up a list of prices that my vendors can choose from for their products? For instance, I sell books on my website that are priced Free, $0.99, $1.99, $2.99, and $3.99. How can I make it so that the vendors have to choose one of those prices instead of entering their own price?
13 years 1 month ago #126729 by Jerome
You will have to modify the view " productmarket | form_price " in order to change how the price is asked in the front-end.
You can replace the input text by a drop down.
Be careful, the price which is submitted to HikaMarket is always the price without taxes. The price with tax, when modified uses the javascript to update automatically the price without taxes.
If you want to display one single field (dropdown) and this field is the price with tax, you will have to replace the input box for the price without tax into an hidden field (and kept the javascript to update the price).
13 years 1 month ago - 13 years 1 month ago #126743 by southga1974
I only see code when I click on the view. How do I replace it in the code?
The way my store is set up now is like this:
When a customer chooses a book, he can choose from one of three formats: pdf, epub, or mobi (or it may be just one format available). Each of those formats has the same price, which varies according to the price set by the author.
I'd like to set it up so that my vendors can upload their file(s) in one, two, or all three of those formats for the customer to choose from, and then select from a list of prices for the book, which are free, $0.99, $1.99, $2.99, or $3.99.
When the customer sees a book he wants to buy, he'll choose a format for that book and then it's added to the cart.
Does this make sense? If you'll look at the-authors-club.com/index.php/component...ct/302-yours-forever , you can see where the customer has 2 formats to choose from and then that chosen format is added to the cart.
Right now, I'm manually adding the books myself, but I have the HikaMarket so that my authors (vendors) can do it themselves. I use Characteristics to add the formats.
Last edit: 13 years 1 month ago by southga1974.
13 years 1 month ago #126821 by Jerome
Well, like I said, it depends of what you want to do exactly (my speech about the price with taxes or not).
I can't help you correctly if I don't have the useful information.
Modifying a view in HikaMarket or HikaShop requires some development skills, depending of what you want to modify it could require some PHP skills.
I am thinking about proposing a simplified " form price " system in HikaMarket but I will need more details about user requirements in order to know what I should do exactly.
13 years 1 month ago - 13 years 1 month ago #126836 by southga1974
Hi Jerome,
I think I've figured out a way to overcome the limitations. However, is there a way to increase the file upload size and types of files? Currently it's only 2MB.
Thanks!
13 years 1 month ago #126868 by Jerome
The upload limitation is a web server setting. This limitation is in your PHP configuration.
HikaShop and Joomla can't override this configuration setting which is global to your website.
Kind regards,
13 years 1 month ago #126947 by southga1974
Okay thank you.
13 years 1 month ago #127144 by southga1974
I'm almost finished setting up my website store. I have looked at all the forums, but I don't see any instructions for displaying a vendor's products on his page. Can someone explain how to do this? I've assigned vendors to my products. Do I need to set up some kind of special module or menu? Please help.
13 years 1 month ago #127151 by Jerome
There are several thread which talk about it already.
You have to create a product listing module and assign it to the vendor page (there is an option in the HikaMarket configuration for that: "modules under the vendor page").
You have to create a product listing module like for the associate it with a category listing menu (with the option to link/associated the listing).
www.hikashop.com/support/documentation/6...html#products_module
13 years 1 month ago - 13 years 1 month ago #127176 by southga1974
I'm sorry, I just don't understand. I've created a module called Author's Books that I would like to have under each vendor's profile, but when I click on the "modules on vendor's page" all I see are links that take me back to the module configuration. What am I looking for? I believe you still have a login on my website, can you look to see what I'm doing wrong? The URL is
removed by a moderator
Last edit: 13 years 1 month ago by Jerome.
13 years 1 month ago #127180 by Jerome
With a working account it will be better :)
Credentials that you send me before does not work/are wrong.
13 years 1 month ago #127193 by southga1974
I will send your login information in a private message.
Thank you.
13 years 1 month ago #127212 by Jerome
Please sent me a full working account.
Including a working : login + password.
13 years 1 month ago #127220 by Jerome
Error
You do not have access to the administrator section of this site.
We're almost there
13 years 1 month ago #127315 by southga1974
What do you mean?
13 years 1 month ago #127327 by Jerome
I mean that the account you gave me does not have the right to login in the backend.
So the account is valid but it requires just some rights to access to the backend.
Time to create page: 0.172 seconds
