Shipping and billing addresses
15 years 4 months ago #20109 by nicolas
You could replace the line:
if($this->shipping_address==$this->billing_address){
by:
if(false){
in both address and address_view files of the checkout view via the menu Display->Views. Then, add some CSS to hide the input:
.hikashop_checkout_shipping_same_address {display:none;}
and remove the label.
15 years 4 months ago #20208 by brainforge
Working OK thanks, but found a couple of issues.
On your demo site:
1. Add product to cart
2.Go to checkout
3. Login as user demo.
4. Untick same address for shipping
5. Edit shipping address - change street.
6. Old address shows for billing, new address for shipping - great.
7. On shipping side delete the address used for billing.
8. Both addresses now use the new address (from 5)
9. Repeat 4 Untick same address for shipping
10. Repeat 5 Edit shipping address - change street.
11. Both addresses now use the new address (from 10).
I would expect address from 5 for billing, and from 10 for shipping.
Clicking of New Button:
In the address form is there a way to tell whether the user clicked the billing or the shipping new button?
Could one be added?
15 years 4 months ago #20267 by nicolas
Thanks. It's fixed on our end. We'll include the fix for next release.
You can already now whether you're editing a shipping or a billing address in the view:
if(JRequest::getVar('type','')=='shipping'){
//shipping
}elseif(Request::getVar('type','')=='billing'){
//billing
15 years 4 months ago #20277 by brainforge
Thanks for the fix.
When editing the getVar('type') is fine.
When the user has clicked the New button it is null.
Could it be set to indicate which New button the user clicked please.
15 years 4 months ago - 15 years 4 months ago #20283 by woes
by:
if(false){
Have done this, the checkbox is gone, however now i have the exact same problem as before, when editing the shipping address also the billing address changes!
Edit: Fixed it by NOT changing the above line to "if(false){" in the view checkout / address_view
Last edit: 15 years 4 months ago by woes.
15 years 4 months ago #20298 by nicolas
@brainforge:
Sure, you need to add .'&type='.$this->type in the href of the a tag of the new button at the bottom of the file address_view.
We'll do that on our end too.
15 years 3 months ago #21155 by woes
For some reason, it doesn't work again, when you add or edit the shipping address, a new address is made and both addresses get changed to the new made one.
I'm absolutely lost now, it worked perfectly and haven't changed anything to our config except for disabling "Auto submit shipping and payment methods selection".
Have tried to enable it again, without success.
Please help, we allready got a complaint of a customer because the receiver got an email saying that the product was paid for and would be shipped to them, while it should be a surprise.. :(
15 years 3 months ago #21170 by nicolas
Do you use the latest version ? Did you change anything in the address views ?
It's working fine on our end so there is no reason it would reselect the billing address when editing the shipping address.
You're talking about emails received by someone else than the person making the order but emails are sent based on the user email and not based on the address since the address information does not contain any email information. So I'm not following you...How would both problems be related ?
15 years 3 months ago #21178 by woes
Yup, latest version, it worked like a charm before, the only thing changed since then is the "auto submit shipping and payment methods selection".
The problem is, the customer ordered, changed the shipping address, and dit not notice the billing address also changed. therefore the receiver got the emails of payment complete etc.
The login credentials i gave you last time still work, maybe you can take a look..
i only have the changes in the views from a few posts before to remove the checkbox, which worked flawlessly..
Besides this problem, just some thoughts, could it be made so that the customer always gets a popup or something for entering the shipping address?
It can also be confusing when creating a new address that there are four addresses (2 left, 2 right). This would instanty solve all the possible issues regarding shipping/billing addresses..
15 years 3 months ago #21191 by nicolas
Again, I don't see how is the address of the user related to the email address ?
We don't keep a track of the websites of each username on the forum, nor of their credentials. Please provide again the information via our contact form.
You can change the system to only display the selected address with the change there: www.hikashop.com/en/support/forum/4-how-...addresses.html#20935
15 years 3 months ago #21204 by woes
Okay that's great, i will implement it when we have this fixed :)
Have send you an email with the credentials ;)
15 years 3 months ago #21217 by nicolas
I just tried to place an order on your website, edited the shipping address and saved the modification. The new shipping address was selected automatically for the shipping address while the billing address was still the first address entered.
So there was no problem for me on your checkout...
15 years 3 months ago #21225 by Bugger101
Latest version? Sweet! :laugh:
15 years 3 months ago - 15 years 3 months ago #21242 by woes
I've tried it as well, and it works like you say!
It seems the problem is ONLY with the "Create new address" button!
I've tried to start with creating a new address instead of editing when facing this problem, now when i first edit the address all goes well.
Tried deleting the new edited shipping address, and creating OR editing the shipping address again, and everything goes wrong again!
So maybe i should just delete the "create new address" buttons for now :P
Last edit: 15 years 3 months ago by woes.
15 years 3 months ago #21253 by nicolas
There is indeed a problem on the current release with some more complex scenarios like this:
www.hikashop.com/support/forum/2-general...art=40&lang=en#20208
We've fix it and it will be in next version.
If you want to hide the new button, you can easily do it with CSS:
.hikashop_checkout_shipping_address_new, .hikashop_checkout_billing_address_new{
display: none;
15 years 2 months ago #23972 by lrazov
I have been trying to follow this thread in order to understand what needs to be done to separate editing on billing and shipping addresses, but I got lost. Could you summarize what changes in what files need to be done so that when I want to have a shipping address different to the billing and add new shipping address, my billing address stays unchanged and I only see one billing and one shipping addresses?
Thank you.
15 years 2 months ago #23988 by nicolas
The only modification to do is this: www.hikashop.com/en/support/forum/4-how-...addresses.html#20935
The rest has been integrated in HikaShop.
15 years 2 months ago #24015 by lrazov
I've tried your earlier suggestion, but when I edit shipping address, billing address is also changed. I want to be able to separate the two types.
Is it something that's been fixed in 1.5.3 as I am using 1.5.2?
15 years 2 months ago #24026 by nicolas
Yes, that has been fixed in 1.5.3. If you're not using the latest edition, you should first update before applying the modification.
I understand that you can't update easily because you modified core files of HikaShop, but you should at least try to update the address handling.
14 years 11 months ago #30109 by SD
I have Version 1.5.3 and I'm having the same issue mentioned earlier in the thread.
If I uncheck the "Using same as billing" and enter a new shipping address, it automatically gets set as the billing address too. Which file would I have to change (or upgrade from the new 1.5.4 release) to fix the issue?
Time to create page: 0.125 seconds
