Shipping and billing addresses
14 years 11 months ago #30126 by jade
Good to know that will be an update version released soon.
:D
14 years 11 months ago #30155 by nicolas
Yes, you should just update. It's way easier.
14 years 11 months ago #30159 by SD
Thanks for the fast replies Nicolas, they're appreciated.
I have a heavily modded version of Hikashop...is there a particular file that I could switch in from 1.5.4 which would fix the issue?
14 years 11 months ago #30213 by nicolas
Then, you should look at updating the files in components/com_hikashop/views/address , the file components/com_hikashop/views/checkout/tmpl/address.php and components/com_hikashop/views/checkout/tmpl/address_view.php and components/com_hikashop/controllers/address.php
14 years 11 months ago #30378 by SD
nicolas wrote:
I've tried your earlier suggestion, but when I edit shipping address, billing address is also changed. I want to be able to separate the two types.
Is it something that's been fixed in 1.5.3 as I am using 1.5.2?
Yes, that has been fixed in 1.5.3. If you're not using the latest edition, you should first update before applying the modification.
I understand that you can't update easily because you modified core files of HikaShop, but you should at least try to update the address handling.
I have version 1.5.3 but the shipping and billing addresses aren't separate. The issue we now have is that if I delete a shipping address, it also deletes the address as a billing address. All the addresses are in one pool.
What would be necessary to have separate handling for billing and shipping addresses? I saw your other thread with a possible solution ( www.hikashop.com/en/support/forum/4-how-...addresses.html#20935 ) but I'm not sure if that will do the trick.
Thanks again for all your help.
14 years 11 months ago #30401 by nicolas
Having a different pool of addresses is not possible.
The solution is see is to hide the unselected addresses. But that won't make a difference for the deletion of addresses.
The only thing I can propose is for you to remove the delete button:
<a title="<?php echo JText::_('HIKA_DELETE'); ?>" class="hikashop_checkout_<?php echo $this->type;?>_address_delete" href="<?php echo hikashop_completeLink('checkout&step='.$this->step.'&redirect=checkout&task=deleteaddress&address_id='.$address->address_id.'&'.JUtility::getToken().'=1'.$url_itemid);?>"><img alt="<?php echo JText::_('HIKA_DELETE'); ?>" src="<?php echo HIKASHOP_IMAGES; ?>delete.png" border="0" /></a>
in the file address_view via the menu Display>Views.
14 years 11 months ago - 14 years 11 months ago #30405 by SD
Is that what the fix at ( www.hikashop.com/en/support/forum/4-how-...addresses.html#20935 ) does?
If an unselected address is hidden, then how would a user go about selecting one of those hidden addresses as a shipping address (for example) if they needed to?
May I ask the rationale behind the decision to pool all the addresses? Having separate handling for shipping and billing addresses is quite common in most ecommerce software.
On the other hand, it can simplify things for users since they only have to enter an address once. It's a double edged sword though as the deletion of a shipping address means it's gone everywhere.
Last edit: 14 years 11 months ago by SD.
14 years 11 months ago #30407 by nicolas
No, the fix there is only to hide unselected addresses.
14 years 11 months ago #30411 by SD
Sorry, edited the post while you were responding.
14 years 11 months ago #30424 by nicolas
Of course they wouldn't.
In the thread you posted the link, the goal was that when the user had entered a shipping address, it wouldn't appear as a selection for the billing address and vice versa.
He would only see the latest address he entered for each shipping and billing.
And in that case, removing the delete icon makes sense since you have only one address for each.
14 years 2 weeks ago #71498 by pattychocs
Please forgive me if I'm repeating previous posts, but I've read a few posts regarding these issues, but haven't quite found or understood the answers as I'm not a developer.
Joomla 1.5.22
HikaShop 1.5.6
Here's my issue:
Billing and Shipping information - When un-checking the "use same address as for billing" box, the same billing address pops up for shipping. Doesn't seem logical. Shouldn't I be seeing another set of empty fields to fill out a different shipping address instead. That's why I checked that box, right? When I do edit or create a new shipping address, it automatically adds it to the Billing side also. So now there's multiple Billing and multiple Shipping addresses visible. Seems very odd, unintuitive, and confusing to customers. How can I streamline this to just one billing address and one shipping address at a time without relying on the customers intuitive abilities? In other words, with all due respect to my customers, how do I dumb this down?
Many thanks in advance!
14 years 2 weeks ago #71741 by nicolas
With next version of HikaShop (it should be available in one or two weeks), the use will be presented with a address edition popup so that he can directly change the shipping address when unticking that checkbox.
To not have multiple addresses displaying you can do like that:
www.hikashop.com/en/forum/4-how-to/67947-setup-questions.html
14 years 2 weeks ago #71748 by pattychocs
Thanks for the quick response! Will try this until the update comes out.
Cheers!
14 years 2 weeks ago #72512 by pattychocs
I tried this fix. When editing the shipping address it still adds it as another new shipping address and also adds it as another billing address. Now there's two billing addresses and two shipping addresses. Please, is there any other workaround to make it so that I have one billing address, and one editable shipping address at a time until the update is released?
14 years 1 week ago #72612 by pattychocs
Nevermind, It did actually work. I just forgot to hit save when I added the code :blush:
Thanks for your help!
10 years 10 months ago #225400 by oceanswims
How do I get the address fields to show during checkout without login or registration? Hikashop used to work just fine, but today it doesn't. I've been working on configuration for other reasons, and I think I've done something unintended.
10 years 10 months ago - 10 years 10 months ago #225916 by Mohamed Thelji
Sorry for the late reply :
Note that to enter an address, you should at least be logged in, or configure your checkout workflow to enable Guest checkout via "Hikashop->System->Configuration->Checkout".
Last edit: 10 years 10 months ago by Mohamed Thelji.
