Is there a way to display all products on one page
14 years 5 months ago #53922 by ExodiusUK
i was wndering if there was a way to display all products one one page like this website: dixiescupcakery.co.uk/cupcakes/favourites/
14 years 5 months ago #53926 by tony@10uk.net
Create an "All Products" category, assign each product to this category. One product may be linked to one or more categories. Publish with a menu to a products listing, selecting that category.
14 years 5 months ago #53929 by ExodiusUK
Thanks for your reply, could you maybe giv e me a brief tutorial on how to do all that as i think i must be doing something wrong as ive tried all that?
Adam
14 years 5 months ago #53930 by tony@10uk.net
Just to be clear what the problem is...
Assuming you have done the above:
- Create Category under product root
- Assigned products into that Category
- Published menu item of type Hikashop_Product_Listing linking to that category
What do you see when you click the menu item? Do you see the products or is it blank.
If blank - are the products themselves published?
Or is your question around getting the product listing to look and feel like the site you referenced?
Each would have very different answers.
Tony
14 years 5 months ago #53932 by ExodiusUK
Well the Product Listing page was blank when i checked it and i did put products in there im sure, but i also want to list the products like the website shown?
Thanks for your help.
14 years 5 months ago #53966 by tony@10uk.net
It's probably best if you start by posting some screen shots:
- your category listing showing your "all prods" cat
- an example product showing it linked to that cat
- your joomla menu config screen
- your hikashop options page from the menu (click link in top right hand corner - basic options)
The format is secondary to getting this bit working.
Tony
14 years 5 months ago #53969 by ExodiusUK
ok i got it work, however, it displays as a click? is there anyway displaying the add to cart buttons on the same page? aswell as the link i showed?
here how it looks: www.cupcakerymk.com/index.php?option=com...oduct&layout=listing
14 years 5 months ago #53970 by tony@10uk.net
I'm seeing add to cart buttons so guess you've found that option :-)
Don't understand what you mean by displaying as a click?
14 years 5 months ago #53971 by ExodiusUK
Hello, yes found that option lol just one more question, is it possible to add a quantity to that page and group options like the site i showed?
Thanks for all your help :)
14 years 5 months ago #53973 by tony@10uk.net
Ok - you have asked a question beyond my knowledge. I'm not an expert and that's not something I have done.
I do know you will have to edit and code the view behind the product listing for your template. I don't believe there are native options for that.
However, everything is possible and if I were you, I'd look at the product detail view and see how it does it and replicate some of the code into the product listing view. But this is a guess.
Best wait for the expertise from Nicolas.
Sorry I can't help more.
Tony
14 years 5 months ago #54065 by nicolas
If you want to add the quantity field on the listing of products you can do like that:
www.hikashop.com/en/forum/4-how-to/24521...product-listing.html
You won't be able to display options or characteristics on the products listing.
Only custom fields of the table "item" (business edition only) can be displayed on the products listings. You would have to create custom fields of the table "item" via the menu Display->Custom fields and turn on the "display custom fields" option of your menu so that the fields are displayed in the listing. You should be able to reach approximately the same display of the "Delivery Options" of your example page.
14 years 5 months ago #54164 by ExodiusUK
i did try that but it didn't work unfortunately, just curious in the demo i saw you can have a drop down list say colors and every time you change the colour the image changes? how do i do that?
www.demo.hikashop.com/index.php?option=c...ow&Itemid=82&lang=en
that one?
regards,
adam
14 years 5 months ago #54249 by nicolas
You can do that with a characteristic:
www.hikashop.com/en/support/documentatio...html#characteristics
Once you add it to the product, you can click on "manage variants" in order to upload one image per variant and the image will change automatically.
