How does Hikashop work for mobile phones?
14 years 4 months ago #56353 by Campos
14 years 4 months ago #56382 by Mohamed Thelji
If you want Hikashop or your web site to work fine with mobile phones, you'll just have to find a Joomla Template that can handle mobile phones.
Hope this will help you :).
14 years 4 months ago #56421 by Campos
Thank you!
14 years 4 months ago #56452 by dado023
sounds great, so if template is made as Responsive Design, HikaShop will behave in responsive manner?
HINT: Look at responsinator.com
if hikashop is made to adapt to the user's viewing environment (mobile, tablet, laptop etc.), than this is really great indeed...is it?
14 years 4 months ago #56521 by nicolas
HikaShop is not responsive yet.
We'll work on that in a few months.
However, some templates, like the mainstream ones, have a "mobile" template mode which adapts your website to mobile phones. That's different from responsive design.
The following user(s) said Thank You: woonydanny
14 years 4 months ago - 14 years 4 months ago #56611 by dado023
i am looking forward to responsive HikaShop, as i plan to use Hika Business in next project, and it will be very important to work well on mobile devices such as tablets, iphones and android devices.
Project is starting in 40days or so, i hope HikaShop will be responsive by that time.
Keep up the good work
Last edit: 14 years 4 months ago by dado023.
14 years 4 months ago #56614 by nicolas
It won't. As I said in my previous message, we'll work on that in a few months.
14 years 4 months ago #56615 by dado023
at that time,will upgrade to responsive version be seamless, as usual?
14 years 4 months ago #56617 by nicolas
It should be yes, as long as you don't modify the views since all the changes will be in the views for that.
14 years 4 months ago #56640 by rikatos
If it helps, I tend to use rockettheme templates in my websites as the have a section in their gantry system that lets you define the exact page positions to display and where to display them on android and iphone device, this is great as the webpage adapts to the device.
14 years 4 months ago #56723 by dado023
but that doesn't change display layout of hikashop product pages, or i might be wrong...?
14 years 4 months ago #56753 by nicolas
You're right.
But there ways to achieve that.
For example you can restrict some menus to the mobile version of the template.
That way, you could duplicate your products listing menu and have one which would display for the mobile version and another one for the normal version.
Then, in the hikashop options of the menu, you could change the number of columns, images size, etc so that it fits properly.
That's not responsive but it already helps a lot for listings.
Then, for then product page, you could change a bit the code to adapt it based on the current menu:
global $Itemid;
if($Itemid==XX){
// display one way
}else{
// display another way
where XX would be the id of a menu.
14 years 4 months ago #57227 by woonydanny
responsive is the way forward.
thanks nicolas for putting it in the roadmap!!
14 years 4 months ago #57271 by dado023
peetree21 wrote: responsive is the way forward.
is there a road-map, or just using figure of speech? :D ...if there is i would like to see what else is next :woohoo:
14 years 4 months ago #57333 by nicolas
It is in the road map.
Next are:
wishlist system
cart management
advanced reporting along with new widget options
badges system
lot of new payment plugins
multi vendor
All that is currently being developed here. Next will be the compatibility with 3.0, PHP 5.4, responsive design, recurring payments.
The following user(s) said Thank You: dado023, woonydanny, PolishedGeek
14 years 4 months ago #57424 by dado023
yes indeed, whishlist system is very desirable for any webshop. Do you have any ETA for it, since it is already under development.
14 years 4 months ago #57426 by nicolas
We hope to have it in next release in august.
14 years 3 months ago #60124 by dado023
i am watching close for next release, since we are already in August....do you expect it soon?
looking forward to your response :whistle:
14 years 3 months ago #60191 by nicolas
We are close to finishing the test phase. So either this week or next week I think.
14 years 3 months ago #60212 by dado023
sounds promising :D.....as soon as it releases i will combine it with HikaSerial
Time to create page: 0.100 seconds
