How does Hikashop work for mobile phones?
14 years 3 months ago #60615 by dado023
i guess it will be this week then :D
14 years 1 month ago #67629 by ottoman
I'm new to Hikashop and very interested in the Mobile Phone option.
Has any progress been made in regards to this?
14 years 1 month ago #67630 by dado023
y, this is what i am waiting as well, ....this is a must, because android tablets these days are almost in every household
14 years 1 month ago #67640 by nicolas
We're currently working on Joomla 3.0 compatibility. Joomla 3.0 will include bootstrap and we'll work on integrating closely with it to have a better display on mobile devices before the end of the year.
14 years 1 month ago #67687 by rodfarrell
I've just finished a site www.cedarwindowsonline.com.au which has a responsive template and Hikashop works very well on android phones with this. The only issue is related to image sizes which results in a very minor alignment problem.
14 years 1 month ago - 14 years 1 month ago #68112 by ottoman
If you could provide some quick work around for the product display boxes which are currently set to scale to 32% of the screen size, perhaps a set pixel width that would work for the iPhone that would be great. I really need a solution and have invested in your product and am trying to use it with a dynamic template.
Maybe offer an option to make product boxes the width of the iphone screen.
I need your help please.
Last edit: 14 years 1 month ago by ottoman.
14 years 1 month ago #68361 by nicolas
You can try to add such CSS in your CSS to have one product per line automatically with screens below 640px:
@media only screen and (max-width: 640px) {
.hikashop_products .hikashop_product{ width: 100% !important; }
But I can't guarantee that it will work.
For next version, we'll have a much more complex system using bootstrap functions on Joomla 3.0 to properly handle the resizing of the element areas.
13 years 9 months ago #87363 by dado023
it has been quite a while ......any latest news regarding this subject?
13 years 9 months ago #87364 by rodfarrell
My experience has been that Verson 2.0 combined with a good responsive template (try any of the Bootstrap based templates from www.joostrap.com for example) works well on mobiles.
13 years 9 months ago #87429 by Eliot
Indeed the last version of Hikashop now use Bootstrap and is responsive on the back and front end!
13 years 8 months ago #90264 by zitelog
Sorry I'm trying the last bussiness version 2.1.0, but it doesn't. Should I configure some things?
13 years 8 months ago #90265 by Jerome
"Bootstrap" is integrated directly in Joomla 3.0
If you use Joomla 2.5, you have to use a responsive template which use bootstrap and activate the option "use bootstrap design" in the HikaShop configuration.
13 years 8 months ago #90266 by dado023
what if i use responsive template which doesn't use bootstrap?
13 years 8 months ago #90392 by Jerome
So HikaShop would not be compatible with and you would have to modify your HikaShop views in order to use the CSS classes for your responsive template.
13 years 8 months ago #90432 by dado023
to bad, because we non-programmers are in the same situation again, nothing new for us, considering vast majority will still continue to use joomla2.5
13 years 8 months ago #90435 by Jerome
There is some bootstrap templates for Joomla 2.5 too.
But Joomla 3.0 decided to use bootstrap for the responsive so we are compatible we it.
We can't be compatible with all, it's just impossible.
13 years 8 months ago #90440 by dado023
for now you should only be compatible with joomla2.5 as a priority, since joomla3.0 isn't recommended for production, this is not said by me, rather by joomla.org them self, as they stated they don't recommend joomla3.0, but you force it.....i see this a big minus for hikashop
13 years 8 months ago #90694 by nicolas
You're right, we should be compatible with Joomla 2.5 as a priority... and we are. We don't force you to use Joomla 3.0 at all. Most of our users are doing websites with HikaShop on Joomla 2.5.
We even allow you to use responsive design on Joomla 2.5 if your template uses Bootstrap, and most responsive templates for 2.5 actually do use Bootstrap !
So I don't see where the minus is for HikaShop ? The minus is rather for your template because everyone (extension developers) is working on being compatible with Bootstrap for responsive design so they will have the same issue with most of the other extensions which need to be responsive.
13 years 8 months ago #90723 by dado023
from my point of view, the minus is conditional usage of responsive feature only if bootstrap is present, not everyone uses bootstrap, .....however regarding responsive behavior, hikashop should have independent css code for responsive behavior, because after all, "responsive" it is only behavior that reacts on user resolution......
my two cents
13 years 8 months ago #90759 by rodfarrell
The issue of compatibility here is really about what the template can do. Joomla 2.5 itself is not responsive. There are various template developers who have developed responsive (many are actually only "semi" responsive) templates, some using Bootstrap and some using their own framework. It is unreasonable to expect Hikashop developers to try to be compatible with every new framework that pops up as these are effectively forks from the Joomla path. Given that Joomla has adopted Bootstrap as the future path and Joomla 3.5 production version is only months away it is really up to template developers to make their templates compatible with that path.
An ecommerce extension like Hikashop is a massive project in its own right. I have used another ecommerce extension (Tienda) that tried to be everything to everyone only to bog the project down with excessive and buggy code. That project has now collapsed and left website developers like me many thousands of dollars out of pocket, having to redevelop all of our clients sites. I for one an very happy that Hikashop is focusing on core Joomla compatibility.
Having recently had the misfortune to inherit a Virtuemart website project I can attest that Hikashop is without doubt the best ecommerce solution for Joomla bar none and more and more template developers will be developing specifically for Hikashop compatibility, which is the way it should be, not the other way around.
Time to create page: 0.123 seconds
