- Thank you received: 5
hikashop plugins - Product Page Clothes Design, Cart Module Design
are there any working demo from this two plugins out there?
www.hikashop.com/marketplace/product/240...-clothes-design.html
www.hikashop.com/marketplace/product/135...t-module-design.html
i saw in the backend of the demo that the "product page clothes design" plugin is installed but unpublished. it is not possible to enable so i can`t see it in action.
Well done, you're right we have set a demo page to show the Design Clothes plugin in action.
Use this link , to see it on our demo website.
For the Cart Module Design, we had set an article to show as well the plugin, but isn't ready yet, I work on it this may be ready quite soon.
hi, is the Cart Module Design article ready?Philip wrote: For the Cart Module Design, we had set an article to show as well the plugin, but isn't ready yet, I work on it this may be ready quite soon.
Yes, it's now done, sorry for the delay, you can see the Demo, here on our HikaShop Demo website.
i can't see the config of the module in your demo website. there for my question, would it be possible to show only the shopping-trolley symbol without articles and with articles in it?
what i want to archive is when there is no article in the shopping-trolley it should show only the trolley, but if there are some articles in it should show the shopping-trolley symbol plus the number how much articles beside of the trolley.
is this possible to set this out of the box with the module?
or do i have to customize this for my needs?
It's possible with just custom Css code, follow me :
First, you have to reproduce this configuration :
image missing https://i.imgur.com/hU5Uf2N.png
Then, you will have to add custom css, to hide unwanted elements, like products price and the second total price :
See this tutorial , to learn how to proceed.
As result, you will have this :
image missing https://i.imgur.com/1xXhtZz.png
I would like to achieve the result from the picture shown below. Unfortunately the linked tutorial is about something else. Could you guide me to the right one, or provide some css code?
I have the cart module in the header top bar and would like to show only the cart symbol, the quantity and the price.
Best regards
Markus
Not sure to follow you, 2 case :
- You have the Design Cart plugin and then I don't understand your needs
- You haven't it, and just Css won't be enough to reproduce this kind of result.
Can you precise from where do you speak please ?
[MODERATOR :]We are really sorry for the answer delay, we have faced an issue with our work tools which lead us to not see your message until now.
This issue only concerns the first message of users, and so we are sorry that our first contact with you didn't go well.
Once again sorry for the inconvenience.
The HikaShop Team
I have implentet the cart module in the menu bar, but it displays the added items as text "3 items for 10.00 €". I would like it to just display the cart icon an the number of articles, without price/total. A nice addon would be to have articles with prices listed on hover/mouseover.
Markus
Can you provide an Url link to better understand the context and be able to precisely answer you.
Precise which part you want delete with a scheme and annotation :
image missing https://i.imgur.com/rBTlSkp.png
For the second point of your question, you have already this kind of feature if you go in your module cart configuration page :
image missing https://i.imgur.com/DfLRrLW.png
Awaiting elements from you to go more far on your subject.
here you see how it is (menu bar):
p506804.mittwaldserver.info/joomla/de/be...x-botschaft-hikashop
That is how I want it to be (also in the menu bar):
www.vaterschaftstest-resultan.de
First, always in order to understand from where we start can you precise if you use the Cart Module Design plugin ?
If yes, you have to published it, I insist on this point because from your link, I see nothing that show this plugin is present and may have to add on your frontend (like fontawesome cart icon by example).
image missing https://i.imgur.com/bOiNqWU.png
Second, you have to provide a screenshot of your Cart Module configuration like I do.
Thanks, to describe from where we start, and provide more elements.
I have bought the plugin and activated it. Attached you find a screenshot. The cart is now beeing displayed as a icon. So far so good, unfortunately there is no option to disable the word "Gesamt" or in english "total" and I would like to set the font weight to thin. But as soon as I am overriding the style from hikashop the the cart icon disappears.
Does this cart design plugin provide a special settings panel.
Ok, follow me step by step :
1. First, you can go to your HikaShop plugin Folder
=> YourWebsite\plugins\hikashop\cart_design
2. Open the cart_design_view.php file
3. Go around line 368
4. By default you will see this :
To have this :
$text = $price_class;
5. For remove the bold effect, in this same php file above line 185, you will find the view Css code, add at the end of the css part this :
Hope this will match your needs
