Mobile view - display 2 products side by side
12 years 2 weeks ago #177876 by lt635
-- url of the page with the problem -- : www.fsfightgear.com.au/
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.4.33
-- Browser(s) name and version -- : any
I am using Hikashop and Bootstrap. Is there a way for the shop products to fall into 2 products in a row on mobile view and not just one? It is a lot of scrolling with only one product in a row.
Thank you
Kind regards
Lene
12 years 2 weeks ago #177897 by lt635
Sorry, this should have been in the 'product and category' topic.
12 years 2 weeks ago #177879 by nicolas
There is no option for that.
With custom CSS you should be able to achieve that:
@media (max-width: 767px){ [class*="span"], .uneditable-input[class*="span"], .row-fluid [class*="span"] { width: 49.5% !important; } }
12 years 3 days ago #179918 by lt635
I will try that.
Thank you
Kind regards
Lene
11 years 6 months ago #201445 by river
Joomla 3.4.1
Hikashop 2.4.0
Yootheme template Unity version 1.0.8 (latest version)
URL: kvikki.no
I also want my stores products to fall into 2 products in a row on mobile view.
I tried the above code. But it only moves the products to the left, using 50 % of the screen, and displaying one product pr. row.
Any more advice ?
11 years 6 months ago #201557 by nicolas
In your case, you want to use such code:
@media (max-width: 767px){ [class*="span"], .uneditable-input[class*="span"], .row-fluid [class*="span"] { width: 49.5% !important; float: left !important; } }
11 years 6 months ago #201576 by river
This is excellent. I looks very good on my HTC mobile phone.
There is only on small problem. That is when the product name is a little long, and it becomes a big gap under the product. (see picture below).
Is it a way that I can make the "product name" font size a little bit smaller when I hold to mobile in narrow view ?
11 years 6 months ago #201589 by nicolas
You want to force the height of the area with such CSS:
.hikashop_products .hikashop_subcontainer { height: 350px !important; }
The following user(s) said Thank You: river
11 years 6 months ago #201641 by river
Perfect, it works like a charm =)
11 years 3 weeks ago - 11 years 3 weeks ago #218859 by river
Is it possible to apply this css code so it is only used on the "categories listning" with all the products, and not on the product page ?
The reason for this is that when I apply the code is put's (in mobile view)the "add to cart" button on the right side off the image, and not below where it should be.
Last edit: 11 years 3 weeks ago by river.
11 years 3 weeks ago #218863 by Mohamed Thelji
A solution can be to use that kind of CSS code :
@media (max-width: 767px){ .hikashop_category_information [class*="span"], .hikashop_category_information .uneditable-input[class*="span"], .hikashop_category_information .row-fluid [class*="span"] { width: 49.5% !important; float: left !important; } }
10 years 6 months ago #237958 by ralph024
I also want to show my products in a row of 2 products on mobile view.
I tried the codes above, but it does not work for each line (See attachment)
Any advice ?
10 years 6 months ago #237975 by nicolas
Please provide a link to the page with that modification in place so that we can have a look at what's going on there.
The following user(s) said Thank You: ralph024
10 years 6 months ago - 10 years 6 months ago #238004 by ralph024
send the links as a private message to you!
And when i enable the Bootstrap option, the loginform in the checkout isn't working correctly
Thanks!
Last edit: 10 years 6 months ago by ralph024.
10 years 6 months ago - 10 years 6 months ago #238009 by lionel75
each first item of row ( the item of the first column) is not manage by the same css code compare to item of other column ( colé and col3) .
this behaviour is explain by this code
.hikashop_product_column_1, .row-fluid .hikashop_category_column_1, .row-fluid-7 .hikashop_product_column_1, .row-fluid-7 .hikashop_category_column_1, .row-fluid-8 .hikashop_product_column_1, .row-fluid-8 .hikashop_category_column_1, .row-fluid-10 .hikashop_product_column_1, .row-fluid-10 .hikashop_category_column_1, .row .hikashop_product_column_1, .row .hikashop_category_column_1 {
margin-left: 0 !important;
clear: left;
so each time hiakshop or css guy ll use !important ; there ll be some area where the default rules of CSS ll not apply and you ll have toknow this area or ask t othe developper howto override this behaviour .
best l lbe e documentation page where hikashop css guy explain how the layout is design or look at the php code .
I do this many months ago ....
Attachment not found
Last edit: 10 years 6 months ago by lionel75.
10 years 6 months ago #238021 by nicolas
Add that CSS and it will work like you want:
.row-fluid .hikashop_product_column_1, .row-fluid .hikashop_category_column_1, .row-fluid-7 .hikashop_product_column_1, .row-fluid-7 .hikashop_category_column_1, .row-fluid-8 .hikashop_product_column_1, .row-fluid-8 .hikashop_category_column_1, .row-fluid-10 .hikashop_product_column_1, .row-fluid-10 .hikashop_category_column_1, .row .hikashop_product_column_1, .row .hikashop_category_column_1 { clear:none !important; }
10 years 6 months ago #238147 by ralph024
Thanks that works perfect! :woohoo:
Is this also possible without Bootstrap? Because when i enable the Bootstrap option, my buttons at the checkout look as in the attachment 1. It first looked always like attachment 2
Thanks!
10 years 6 months ago #238148 by nicolas
The CSS of your template is quite messy.
Then you can turn off bootstrap, and use such CSS to make the listing responsive wtihout bootstrap:
www.hikashop.com/forum/product-category-...p-option.html#211235
10 years 6 months ago #239606 by ralph024
Thanks it works ;)
