Products
12 years 3 months ago #165592 by Ncom
Products was created by Ncom
I want to display my products next to each other like 4 or 5 on a row. Now
irt shows like this www.ncom.be/categories-listing/category/socket-1150
Something I forgot?
Best Regards, Wesley
12 years 3 months ago #165600 by Jerome
Replied by Jerome on topic Products
Your link does not work. I got a 404 page.
12 years 3 months ago #165616 by Ncom
Replied by Ncom on topic Products
hHi,
sry
www.ncom.be/hikashop-menu-for-categories...egory/21-socket-1150
I also have a dot point in front off my product. What is that?
Best Regards,
Wesley
12 years 3 months ago #165666 by Ncom
I have taken some pictures because it's wierd I can get it right and those point in front of every categories and products are like mixt-up.
12 years 3 months ago #165621 by nicolas
Replied by nicolas on topic Products
Both issues comes from the fact that you turned on the "use bootstrap design" option of the HikaShop configuration while your Joomla template is not compatible with bootstrap. Turn off the option and it will solve both.
12 years 3 months ago - 12 years 3 months ago #165677 by Ncom
Thank you :-)
Ok that's one step. Now I want that the catogories only show in the left menu and not on my main page
Best Regards,
Wesley
Last edit: 12 years 3 months ago by Ncom.
12 years 2 months ago #165682 by nicolas
I do see it right under the other text: take.ms/6uoD9
12 years 2 months ago #165864 by Ncom
Yes I know but I don't want that the shop shows the categories de sub catogeries on my main page like in the screenshot above.
Because the categories al already in the left menu
12 years 2 months ago #165869 by Mohamed Thelji
Replied by Mohamed Thelji on topic Products
Does it solve your issue if you set the "Show sub categories" option of the category listing content menu which have the id number 109 to NO CHILD.
12 years 2 months ago #165972 by Ncom
no doesn't work. My left subcategories in the menu dissappears en in the main pages they stay. It's the otherway I want it.
Best Regards, wesley
12 years 2 months ago #166029 by nicolas
Then, you need instead to edit the left module (id 100) via the menu Display>content modules and set the "Link on main categories" option to "no". Then, it should work like you want.
12 years 2 months ago #166062 by Ncom
Thank you.
But now the arrow stands in the way lol. I think murphy is @ work :)
12 years 2 months ago #166253 by nicolas
This is just a CSS issue that you can easily solve by adding that CSS code on your website:
.pane-sliders h3.title span{ padding-left : 20px !important; }
12 years 2 months ago #166309 by Ncom
Thx,
And in witch file do I have to put it?
Best Regards
12 years 2 months ago #166339 by nicolas
As explained in the documentation link I gave, you can add it in the frontend CSS file of HikaShop via the Display tab of the configuration.
11 years 11 months ago #177292 by Ncom
I have a new Theme for my webshop but have some problems.
When I click on processors for example and then socket 1150 I getting a new black page.
I want them to show up next to my menu. I added some pictures so you can see what to
problem can be.
Kind Regards
11 years 11 months ago #177312 by Mohamed Thelji
I just tested it and I'm correctly redirected to a product listing : www.ncom.be/menu/category/socket-1150
The following user(s) said Thank You: Ncom
11 years 11 months ago #177420 by Ncom
what I want is when I click for example on processors that it gives me a dropdown menu (categorie on 2 levels) and when I push
socket 1150 is give me the products next to my menu. Now I have like a menu with sub categories and a second menu that makes
Socket 1150, Socket 2011-V3, etc. that last I don't want that.
1. I need categories on 2 levels menu with subcategories in a dropdown menu
2. That my products show next to my menu. Now it just opens a new page
I hope this information is good enough to give me a good solution
kind regards
11 years 11 months ago #177422 by nicolas
So if I understand correctly, your problem is that the module of the categories on the left disappears when you click on a category ?
To avoid that, you need to edit your category module via the Joomla modules manager and make sure that you assign it to all the hikashop menu items, espcially the "hikashop menu for category listing").
11 years 11 months ago #177494 by Ncom
well kind of yes. But already fixed the menus now. but when I click for example processors --> Socket 1150 It just opens
a new windowpage (try it) but this is not how I want it. I just want when I click on it it just opens next to my menus
Time to create page: 0.533 seconds
