Add custom »Layout on Product Page«
10 years 9 months ago #230029 by iq-guru
thanks for the second effort. But it is still not solving the problem. I can observe that this happens only with the pinterest button.if i disable this in the backend section of the plugin it works fine.
Thanks in advance for your work!
have a great week
carsten
10 years 9 months ago #230082 by Philip
For a reason or another this link did't allow me to acces your website...
And so, I'm not able to help you right now...
10 years 9 months ago #230102 by iq-guru
Hi Philippe,
sorry - i just worked also and changed some structural things so perhaps the link was renamed by this.
Ok here you can see the problem right in the socila bar:
dev.iq-guru.com/angebote/shop/alle-produ...schickt-zu-verwalten
If you need any more please let me know!
Thanks in advance
carten
10 years 8 months ago #230147 by Xavier
Please try to install the attached plugin, if that solve the issue so please confirm that.
Else we will need a backend and FTP access to debug that issue directly, I think that you have a problem due to the description of your product.
10 years 8 months ago #230153 by iq-guru
Hi Xavier,
first thank you for your incredible support! I´m ver happy that i switched from MiJoShop to Hikashop.
Even unfortunately with the new plugin i have still the same problem :-(.
Ok so is there a save place to sent you ftp and admin credentials for my dev site?
Thanks in advance for your help!
carsten
10 years 8 months ago - 10 years 8 months ago #230161 by Philip
When you want to pass us some references, there is only one way : our "Contact Us" form
Important : Add in the message subject, this topic subject to keep the link.
Awaiting your references to go more far.
Last edit: 10 years 8 months ago by Philip.
10 years 8 months ago #230300 by iq-guru
Ok just passed them via contact form.
10 years 8 months ago #230515 by nicolas
The FTP account you provided goes to a web server where there is no HikaShop installed.
take.ms/wxNQN
So we still were not able to look at the issue on the website.
Could you check the credentials you provided ?
10 years 8 months ago #230579 by iq-guru
sorry you just took the wrong path :-)
the dev site is under /subdomains/dev/httpdocs/...
So the credentials are correct just look in that path and you can find the installation.
Thanks a lot!
Carsten
10 years 8 months ago #230622 by nicolas
Ok, I found the issue. The plugin was working with simple tags, but you had a more complex tag with uppercases, spaces and a pipe and these were not taken into account. I've modified the code to take these into account too.
See, that's why I asked you to provide the tags that you were using so that we could be sure to take everything into account...
The modifications will be in the next version of HikaShop.
10 years 8 months ago #230686 by iq-guru
Nicolas,
THANKS SO MUCH!
I raly apriciate your support at hikashop! I thought the nonumbers documentation would have explained this better then i could as i learnd from them :-)
Anyway i´m very happy that this works now!
Thanks and have a great weekend !
Carsten
11 months 3 weeks ago #369462 by huwhuw
Hi I am trying to do a UIKT layout for hikashop product page
modifying
yootheme > product / show_default.php
Has no effect on the product page any more
How do i add custom modifications please?
11 months 3 weeks ago #369464 by nicolas
If the modifications have no effect, it's likely that you're not editing the correct layout.
While product / show_default is indeed the default layout for the product details page, HikaShop comes with other layouts.
The best is to use the "Display view files" setting in the HikaShop configuration in order to find out which view file you're using where you want to do your modifications:
www.hikashop.com/support/documentation/5...g.html#advanced_main
11 months 3 weeks ago - 11 months 3 weeks ago #369497 by huwhuw
[strike]Thanks this is my layout.
I would like the text "Framed 40cm x 50cm Unframed 75cm x 65cm "
To be to the right of the image and the add to cart etc underneath the text.
I have tried editing both frontend/yootheme/product/show_product.php and cassiopeia page but nothing changes.
I have dragged every element to the right and the description from the bottom but my layout is still unchanged.
I have cleared my cache.[/strike]
Ok fixed here is a uikit layout override - there must have been a sticky cache because it eventually reloaded correctly.
Last edit: 11 months 3 weeks ago by huwhuw.
