Sorting products
10 years 7 months ago #237047 by Geor
Sorting products was created by Geor
I am trying to give the customer, the option to sort products by price for example . Is there any way I can do this ?
10 years 7 months ago #237053 by nicolas
Replied by nicolas on topic Sorting products
Yes. You can use a filter of the type "dropdown" and with the "apply on" option set to "sort" and then select the columns on which you want to be able to sort.
www.hikashop.com/support/documentation/1...-filter-listing.html
You can do that via the menu Display>Filters in the Business edition.
10 years 7 months ago - 10 years 7 months ago #237067 by vanway
Replied by vanway on topic Sorting products
Hi NIcolas,
I tried to do it but got no luck, no filter appears anywhere. Did the exact same example.
Just one question, When the filter is created, should it appear in every product list, or we have to assign a menu to filters?
Solved: Forgot to put yes on the display main to show filters.
Last edit: 10 years 7 months ago by vanway.
10 years 7 months ago #237079 by nicolas
It can appear on all the products listings (like how you configured it), but in each menu item, you also have a similar option so that you can activate/deactivate it for a specific menu item.
The following user(s) said Thank You: vanway
9 years 11 months ago #256859 by Geor
Replied by Geor on topic Sorting products
Is the sorting option available in the Essential edition ?
9 years 11 months ago #256860 by Jerome
Replied by Jerome on topic Sorting products
As written in the documentation page given by Nicolas :
Filters are only available in the Business edition of HikaShop.
So the filters are not avilable in Essential edition of HikaShop.
