I would need a conditional product sequensing
9 years 10 months ago #256285 by nicolas
That looks ok to me. Note that if you have variants in these products, you need to enter the id of the variants in the array, and not the id of the main product.
9 years 10 months ago #256297 by steph3838
Thanks Nicolas, that's also what I thought :)
Now we try to check the cart content when the customer clicks the "Panier" button.
This is only valid if the customer comes form a "A la carte" link or sublink :
We have to be sure that the customer does not remove a product from Etape 1 if he has a product from Etape 2 in the cart.
If he does so we want him to be redirected to the A la carte main menu entry and it's cart emptied.
Have you maybe an idea how we could reach this ?
Thanks in advance for your help and advise,
PS : the "A la Carte" menu control works with the Regular Labs ReReplace extension !
Best regards
Stéphane
9 years 10 months ago #256302 by nicolas
I would recommend to implement the onAfterCartProductsLoad trigger of HikaShop in a custom HikaShop plugin. That way, in that trigger, you can check the products in the cart and redirect automatically where you want (with the redirect function of Joomla docs.joomla.org/API15:JApplication/redirect ) when necessary.
Time to create page: 0.165 seconds
