Product custom field values not saving in backend of product
6 years 10 months ago #314698 by elevology
-- Joomla version -- : 3.9.13
-- PHP version -- : 7.2.22
-- Browser(s) name and version -- : firefox mac
-- Error-message(debug-mod must be tuned on) -- : No error message present on the page
I have a multi-select custom field added to a product. When I navigate to the back-end of the product, make a selection or two from the multi-select and save, some values save and some do not.
An example: Multi-select custom field name "Mounting" with the following structure.
Mounting
- Horizontal Mounting
- Vertical Mounting
- 1" Pipe Mounting
- 1-1/4" Pipe Mounting
If I select Horizontal Mounting or Vertical Mounting or both, the values save into the product. If I select 1" Pipe Mounting or 1-1/4" Pipe Mounting the values do not save. It seems like the double quote in the value is causing an issue. Perhaps the custom field values need to html entity encoded before they're placed into the option value="" in the DOM.
6 years 10 months ago - 6 years 10 months ago #314703 by Philip
Can you provide theses elements in order to better understand the context ?
we need :
- A screenshot of your relative custom field setting page
- Any relatives elements that will help us to reproduce your configuration on our side
Awaiting news to progress on your subject.
Last edit: 6 years 10 months ago by Philip.
6 years 10 months ago - 6 years 10 months ago #314720 by elevology
Last edit: 6 years 10 months ago by elevology. Reason: wrong screenshots added
6 years 10 months ago - 6 years 10 months ago #314721 by Philip
Thanks for your returns ! It able us to improve our code to manage specific cases like yours, here you have some " and start your value by a number, both of these leads to a bug.
You can now update to have the fix, and your solution.
6 years 10 months ago #314768 by elevology
Hello, I went into my subscriptions and downloaded hikashop but it's showing v4.2.2 which is the version I already had installed prior to reporting this bug. Does this download contain the bug fix I need even though you didn't increment the version number?
6 years 10 months ago #314822 by nicolas
Yes. We made a hot patch we've added to the current release so that you can get the fix easily. Since it's not a big problem we'll wait for the next release for everyone else to get the patch. Otherwise, if we were doing a new release each time we fix a small issue, we would do a release each day which would bother everyone for fixes they don't care about.
6 years 9 months ago - 6 years 9 months ago #314942 by elevology
Hello, I'm not sure how you patched this but I need to report some more bugs here. ® ® breaks it. I'd recommend some kind of unit test here, testing your function against a variety of characters.
Last edit: 6 years 9 months ago by elevology.
6 years 9 months ago #314945 by elevology
The ampersand (&) symbol also breaks it.
6 years 9 months ago #314974 by nicolas
Thank you for your feedback. We've added another patch for that.
6 years 9 months ago - 6 years 9 months ago #315040 by elevology
™ ™ also breaks it
6 years 9 months ago #315041 by elevology
Also something in this string breaks it: CAT 4, 40 cal/cm2
6 years 9 months ago #315042 by nicolas
I'm not able to reproduce the issue with either of your two last examples thanks to the patch we've added 2 days ago here www.hikashop.com/forum/product-category-...-product.html#314974
So make sure you've downloaded the install package on our website and installed it on your website again to get the patch.
