- Thank you received: 1
Product Listing with Variant Display
If you activate the "popup mode" setting of your listing (in the settings of the menu item), then the "choose options" will display a popup with the product details in it where you'll be able to select the variant and add to cart. You can then close the popup and you'll still be on the listing.
But it's not possible to directly display the variant dropdown(s) on the product listing.
First, you have to go to your relative Item Menu (that manage your product listing) :
- Menus => Main Menu, and click on the relative product listing title.
- Go to Products options tab, and go in Product data display part
- See my screenshot :
This option will allow you to have a popup to display product page without moving from the listing.
In Characteristic settings (Products dropdown => Characteristics), and click on the characteristics you want display on your product listing.
BUT that's just a display, not a way to select variants from the product listing.
This option is available since the HikaShop 4.6.0, don't forget that you can follow HikaShop progress thanks to our Blog, here ( 4.6.0 article ).
eduprint.satumalaysiahosting.com/all-products
yes, indeed it is my fault, I forgot that this option works ONLY for the listing div, and not on the listing table...
BUT maybe there a third voice, see my screenshot :
In listing DIV you have the Items part, and the "Table switcher" option, that allow your customer to dynamically change the product listing display (list sty or div).
Hope this will fit your expectations.
