Product picture not showing....
2 years 2 weeks ago #363996 by notnilla
and we tried using the Product add button and tried this syntax
Neither worked. We're used this product for years without issue. Now the picture loaded (we loaded and unloaded that too) does not show on the page. Also when clicking the "Choose Options" button, the next page shows a tiny restricted picture much smaller than the 100 x 100 of all our other pictures. When this first began, the correct syntax picked up the product for Thursday tickets (name is not similar, ID number is not even close) and at least that is not happening anymore. We're stumped. Thank you in advance for your efforts. We appreciate you very much. Catherine" class="hasTooltip topictitle">Product picture not showing....
was created by notnilla
-- HikaShop version -- : 5.1.1
-- Joomla version -- : 5.2.0
-- PHP version -- : 8.2.23
-- Browser(s) name and version -- : Safari 18.0.1
A long time product is no longer acting in a regular manner. We use syntax to have it appear in a Joomla article. Syntaxed used:
Catherine
2 years 2 weeks ago #363997 by nicolas
From what I can see on your pages, it seems that HikaShop thinks that there are several images linked to this product. However, the main (first) image is invalid or doesn't exist anymore for some reason, and HikaShop is not able to process it. This is why the image doesn't appear with the tag.
On the product page, HikaShop displays two areas for the images:
- the main area, which displays the main image in a bigger size
- the thumbnails area, which displays a smaller image of each image linked to the product
That second area only appears when there are several images linked to the product.
And the small image you see on the product page of that product is in that second area. So that means that it must be the second image linked to the product, and that the first image can't be processed, and that's why it doesn't appear in the main area, nor in the thumbnails area.
So, I would recommend checking the images of that product. Delete them all, save the product once, and add back the one with works. It should hopefully be enough. Otherwise, you can always unpublish this product, create a new one with the same information and the image, and change the id in your tag so that it uses the new product. That will circumvent the problem.
The following user(s) said Thank You: notnilla
2 years 2 weeks ago #364017 by notnilla
Thank you very much. I scrubbed all the graphics and thumbnails, gave it a new one and it's not showing. The second page is showing the new graphic. Odd. We'll do the new product now. Thank you for all your help.
