Products listing display in DIV with variants and basket
1 year 8 months ago #365955
by erix
Adishatz, erix
www.agerix.fr
Products listing display in DIV with variants and basket was created by erix
-- HikaShop version -- : 5.1.5
-- Joomla version -- : 5.2.3
-- PHP version -- : 8.3.16
-- Browser(s) name and version -- : Chrome 133,0,xxx
Hello
I have search in the forum and the doc and I don't find my answer so, here I am
I'm looking for a way to display my products like this (not an hikashop website)
But I get this with Kikashop
Is there a way to do it with Hikashop ?
Thank you for your answers
Hello
Adishatz, erix
www.agerix.fr
1 year 8 months ago - 1 year 8 months ago #365960
by Philip
Replied by Philip on topic Products listing display in DIV with variants and basket
If we speak about display and other aesthetic adjustments, then you can use custom Css command, learn here how to process.
Now If you are talking about something else such as having dropdowns, or other elements, then you need to edit your Item Menu :
Here, you will have several setting to define to display elements or not.
Last edit: 1 year 8 months ago by Philip.
The following user(s) said Thank You: erix
1 year 8 months ago #366020
by erix
Adishatz, erix
www.agerix.fr
Replied by erix on topic Products listing display in DIV with variants and basket
Hello Philip,
Thank you for your answer. I was talking about droplist. as you can see on my screenshot I have a button with a label who says "Choose options" and redirecting to the produc page. I'm searching a way to have droplist directly on this page with variants and the add to cart button.Actually, iIt is not the case and I don't find a way to set it.
Here is my menu setting
and here is the category listing
as you can see, for "millesime" I have a list of values instead of a droplist.
To be as complete as possible, here is the product page
Adishatz, erix
www.agerix.fr
1 year 8 months ago #366022
Replied by nicolas on topic Products listing display in DIV with variants and basket
Having the characteristic selector directly on the listing is not possible.
That's why the "add to cart" button turns into a "choose options" button which directs to the product page.
What you can do is to change the "popup mode" setting of the menu item. That way, you can have the "choose options" button open a popup with the product details page inside for the selection of the characteristics and add to cart. That way, the customer still stays on the listing page.
Now, if you really want the exact same display with the dropdowns, it's possible, but not with characteristics.
You would have to use instead custom item fields. With custom item fields, you can display them directly on the listing with the add to cart button. Now, you can't change the price of the product based on the selection of the custom item fields. You could with the "price calculations" plugin, but it would still be difficult to have different values in the dropdowns for different products, and have the prices vary based on the different values in the dropdowns of different products without any fixed rule. It's not impossible but would require a complex setup of custom product and custom item fields and formulas in the price calculations plugin.
I would highly recommend to go with the popup mode if possible since you already have setup your characteristics / variants the way you want.
