Problem with "Always stay on the same page"
11 years 4 months ago - 11 years 4 months ago #206871
by sokartch
Problem with "Always stay on the same page" was created by sokartch
-- Joomla version -- : 3.4.2
If an item has custom fields "After a product is added to the cart" Option is meaningless. It always jumps to the cart page.
> For the other issue, please try to create new threads for new questions. I tried to look at that other issue on your
> website but I wasn't able to access your HikaShop configuration with the user access you provided which is a
> requirement to be able to look at the problem.
I improved rights mentioned in
www.hikashop.com/forum/install-update/87...ong-total-price.html
to "Super User"
to "Super User"
Last edit: 11 years 4 months ago by sokartch.
- Thank you received: 1778
11 years 4 months ago #206900
by Mohamed Thelji
Replied by Mohamed Thelji on topic Problem with "Always stay on the same page"
I just tested it on my end and it worked fine, can you give me a link to one of your product which has an Item custom field so that I can directly test it on your end ?
11 years 4 months ago #207011
by sokartch
Replied by sokartch on topic Problem with "Always stay on the same page"
Hello
www.sokart.ch/cms/e-shop/nach-kategorien...category_pathway-331
and choose "In den Warenkorb"
Then click tab "Lasergravur",
then first product "Lasergravur "Maria""
Then choose "Sujet" and "In den Warenkorb"
You will see the cart... instead of stay on the same page...
Petar Ristanovic
www.sokart.ch
Petar Ristanovic
www.sokart.ch
11 years 4 months ago #207031
by Xavier
Replied by Xavier on topic Problem with "Always stay on the same page"
We are not able to reproduce the issue on our end, please send us a backend and a FTP access via our contact form, don't forget to give the url of that topic in the message.
11 years 4 months ago - 11 years 4 months ago #207247
by sokartch
Ok, I wrote emaill
www.sokart.ch/cms/
- Please empty the cart
- www.sokart.ch/cms/e-shop/nach-kategorien...category_pathway-331
(product with no "custom fields" options)
- You may add product, it stays on the product page...
Then:
- www.sokart.ch/cms/e-shop/nach-kategorien...23-lasergravur-maria
- Choose "custom fields" options
- Add to chart...
- It jumps to cart site.
Important:
- Jump return to product page and choose the same "custom fields" options...
- Add to chart
- Notthing happens, the product acount in the cart ist the save as former.
www.sokart.ch/cms/
Then:
- Add to chart...
Important:
- Add to chart
11 years 4 months ago #207460
by Xavier
Do you have edited views ? I can see that you have tabs on your product pages but you are not using the "show_tabular" view.
When looking at the html of the page, I can see that the inputs which are giving the return_url information, and other informations are out of the html form, so the informations are not given and that's why by default it redirect to the checkout.
Please check your modifications in order to put the inputs inside the form.
11 years 4 months ago - 11 years 4 months ago #207583
by sokartch
But I have not changed any view!
This is probably the solution:
www.hikashop.com/forum/checkout/877982-p...-and-pagination.html
Regards!
Regards!
