- Thank you received: 2
Problem with address
9 years 6 months ago #268552
by jenbain
Problem with address was created by jenbain
-- Joomla version -- : 3.7.0
-- PHP version -- : 5.6.30
-- Browser(s) name and version -- : Firefox 53.0
-- Error-message(debug-mod must be tuned on) -- : Not error message - problem
I have a problem after registration.
1. User Registers - All good
2. User Logs in - All good
3. User orders product on site - all good.
4. User goes to checkout all good until we get to Shipping
The Address that the user entered at the time of registration is not in the list of addresses. The address is empty, so the user needs to then re- fill the address details again. [This is the issue I want to fix please.]
What have I missed that is not allowing the address details at registration to not come across to Hikashop address.
Any help or direction on where I might fix this would be greatly appreciated.
Kind regards
Jennifer
Kind regards
Jennifer
9 years 6 months ago #268561
Replied by nicolas on topic Problem with address
The issue is that you're using the Joomla registration page, and thus the joomla address fields, which are different from the HikaShop address fields.
You should activate the "Redirect Joomla registration to HikaShop plugin" via the Joomla plugins manager in order to use the HikaShop registration form.
That way, the address the customer will enter when registering on the registration form of your website will be saved as a HikaShop address automatically.
The following user(s) said Thank You: jenbain
9 years 6 months ago #268613
by jenbain
Replied by jenbain on topic Problem with address
Thanks for getting back to me Nicolas, I thought it would be something simple I hadn't done.
Appreciate your time.
Kind regards
Jennifer
Kind regards
Jennifer
9 years 6 months ago - 9 years 6 months ago #268614
by jenbain
Please ignore this one, it seems to be working now.
Kind regards
Jennifer
everything with the registration is now working fine, thank you.
However I have lost the Recaptcha that was working.
1. I have installed the Hikashop recaptcha and set it up, but it is not showing on the registration page.
2. I disabled the Joomla Recaptcha plugin and still no success
Any further advice would be appreciated.
Kind regards
Jennifer
Through out the day I have done the following:
I have read and followed the documentation listed below without any luck:
Integration with recaptcha
I read through this thread and checked that the Joomla Recaptcha was deactivated in the plugin and also under User manager recaptcha - set to none selected, with no change to the page:
Thread - recaptcha-plugin-on-registration.
I am not sure what else to do, your advice and direction would be greatly appreciated.
Jennifer
Kind regards
Jennifer
Kind regards
Jennifer
Jennifer
Last edit: 9 years 6 months ago by jenbain. Reason: Site now working
9 years 6 months ago #268625
by Jerome
Replied by Jerome on topic Problem with address
So, your issue is solved ?
9 years 6 months ago #268646
by jenbain
Yes, thank you Jerome
