- Thank you received: 3
Thema: Problem mit PayPal-Zahlung in HikaShop - "Es ist ein Fehler aufgetreten"
- WEBMONTEUR
1 year 10 months ago - 1 year 10 months ago #365259
by WEBMONTEUR
Thema: Problem mit PayPal-Zahlung in HikaShop - "Es ist ein Fehler aufgetreten" was created by WEBMONTEUR
www.alpaka-kiste.de
-- HikaShop version -- : 5.1.2
-- Joomla version -- : 5.2.3
-- PHP version -- : 8.3.12
-- Browser(s) name and version -- : Firefox, Chrome, Edge, egal
Hello everyone,
I have a problem with PayPal payments in HikaShop and hope someone can help me.
When I click on "PayPal" in the shopping cart, a small popup with a blank white page always appears, which shouldn't happen. If I close this window, another small popup appears with the prompt "Confirm your identity." There, I can choose to receive an SMS, but then an error message appears saying, "An error occurred."
The strange thing is: sometimes the payment works, but this error occurs quite often.
I have already checked the following:
The API settings for PayPal in HikaShop are correctly configured (Client ID and Secret).
HTTPS is active for the entire website.
I have disabled pop-up blockers and tested it in different browsers.
My PayPal account is active and unrestricted.
Still, the error persists. Does anyone have an idea what might be causing this or what else I could check?
Thank you in advance for your help!
Hello everyone,
Last edit: 1 year 10 months ago by Philip.
1 year 10 months ago - 1 year 10 months ago #365267
by Philip
Replied by Philip on topic Thema: Problem mit PayPal-Zahlung in HikaShop - "Es ist ein Fehler aufgetreten"
First of all, note that you have a part of our forum dedicated to messages in German, here .
And that’s why I took the liberty of translating your message into English.
Now to continue on your topic, we are going to need these elements:
- An Url link to allow us to process some tests
- Your Paypal settings screenshot (hide secret references)
- Do you know what distinguishes the commands that present this problem?
(particularity of currency, country of delivery or invoicing, etc.)
- WEBMONTEUR
1 year 10 months ago #365270
by WEBMONTEUR
Replied by WEBMONTEUR on topic Thema: Problem mit PayPal-Zahlung in HikaShop - "Es ist ein Fehler aufgetreten"
Hallo,
vielen Dank für die schnelle und hilfreiche Antwort sowie den Hinweis auf den deutschen Teil des Forums – das werde ich mir gerne anschauen!
Ich habe alle von Ihnen genannten Anforderungen erfüllt:
Der URL-Link für Tests: www.alpaka-kiste.de/alpaka-shop
Ich hoffe, dass diese Informationen Ihnen helfen, das Problem genauer zu analysieren. Vielen Dank nochmals für Ihre Unterstützung!
Beste Grüße
Harry
--- engl. ---
Thank you for the quick and helpful answer and the reference to the German part of the forum - I'll be happy to take a look at that!
I have met all the requirements you mentioned:
The URL link for testing: www.alpaka-kiste.de/alpaka-shop
I hope this information helps you to analyze the problem more closely. Thank you again for your support!
Best regards
Harry
Beste Grüße
Harry
--- engl. ---
Best regards
Harry
1 year 10 months ago #365272
Replied by nicolas on topic Thema: Problem mit PayPal-Zahlung in HikaShop - "Es ist ein Fehler aufgetreten"
I think you have this issue:
www.hikashop.com/support/documentation/4...out-form.html#issuesSupposing that the buttons are displayed, if you click on the "PayPal" button and you don't get the PayPal payment popup, or you get a blank popup on top of the normal popup, it's likely you have a problem with the Cross Origin Opener Policy of your website. You need to configure your HTTP headers plugin, via the Joomla plugins manager and change its "Cross-Origin-Opener-Policy" setting to allow for it.
- WEBMONTEUR
1 year 10 months ago #365309
by WEBMONTEUR
Hallo zusammen,
vielen Dank für eure Hilfe und die Anregungen! Ich wollte euch mitteilen, dass ich den Fehler gefunden habe.
Das Problem lag tatsächlich an den API-Einstellungen im PayPal-Plugin von HikaShop. Nachdem ich die Einstellungen überprüft und korrigiert habe, funktioniert jetzt alles einwandfrei. Insbesondere hatte ich die falsche Umgebung (Sandbox statt Live-Modus) eingestellt, was das weiße Popup und die Fehlermeldungen verursacht hat.
Ich habe alles nochmal getestet, und jetzt klappt die Zahlung reibungslos – keine weißen Popups mehr, und die Zahlung wird erfolgreich abgeschlossen.
Vielen Dank nochmal für eure Unterstützung!
Viele Grüße,
Harry
Hello everyone,
Thank you for your help and suggestions! I wanted to let you know that I found the error.
The problem was actually due to the API settings in the HikaShop PayPal plugin. After checking and correcting the settings, everything is now working fine. In particular, I had set the wrong environment (sandbox instead of live mode), which caused the white popup and error messages.
I tested everything again and now the payment works smoothly - no more white popups and the payment is completed successfully.
Best regards,
Harry
Viele Grüße,
Harry
Hello everyone,
Best regards,
Harry
