Problems with internal product search
11 years 1 week ago #219216 by sergiobertini
1) OK I'll check in my translation file!
2) The problem occurs in both (Administration and website);
I have a replacement seen in "cart / Showcart" but it is needed. Follows the topic link
hikashop.com/forum/wishlist/873962-new-p...shlist.html?start=20
Always logged in!!!
Help me!!!
11 years 1 week ago #219236 by Xavier
2/ In your case, the wishlists can be seen by everybody, right ?
But only the wishlist owner can edit the wishlist name, I think that your issue is coming from there.
If the wishlist owner edit the name, is that working ? We have checks by default to not allow anybody to edit the wishlist of another customer. So you will maybe have to add some code to allow modification of the name by anybody.
11 years 1 week ago #219304 by sergiobertini
So in my case it is necessary to display all the lists registered. For non-registered users can view them.
Before I upgrade to version 2.6.0 this problem did not occur!
Help me!!!
11 years 1 week ago #219342 by Xavier
I just read again your message and as the problem is present in backend too, so this is another thing
Please give us a backend and FTP access to your website, we will debug it directly.
You can send the informations via our contact form (with a link to that topic in the message).
11 years 1 week ago #219487 by Xavier
Please replace the function "save()" in administrator/components/com_hikashop/classes/cart.php by this code:
function save(&$cart) { $app = JFactory::getApplication(); $currUser = hikashop_loadUser(true); $user = JFactory::getUser(); $session = JFactory::getSession(); if($app->isAdmin()) { if(isset($cart->cart_name)) $cart->cart_name = strip_tags($cart->cart_name); if(isset($cart->user_id)) $cart->user_id = (int)$cart->user_id; if(isset($cart->cart_type)) $cart->cart_type = strip_tags($cart->cart_type); $cart_id = parent::save($cart); } else if(!isset($cart->user_id) || !$app->isAdmin() || $currUser->user_cms_id == $cart->user_id || (isset($cart->session_id) && $session->getId() == $cart->session_id)) { if(isset($cart->cart_name)) $cart->cart_name = strip_tags($cart->cart_name); if(isset($cart->cart_share)) $cart->cart_share = strip_tags($cart->cart_share); if(isset($cart->cart_type)) $cart->cart_type = strip_tags($cart->cart_type); if(!empty($cart->cart_params) && !is_string($cart->cart_params)) $cart->cart_params = json_encode($cart->cart_params); if(!isset($cart->user_id) && empty($cart->cart_name)) $cart->cart_name = ''; if(!isset($cart->cart_id) && empty($cart->cart_coupon)) $cart->cart_coupon = ''; $cart_id = parent::save($cart); } else { $cart_id = $cart->cart_id; } return $cart_id; }
This will solve the backend issue, for the frontend the multi cart mode was disabled, that's why there was restrictions on the carts, so I enabled it and now the name can be set on frontend.
