SJ Mini Cart Pro - See character as other product
10 years 4 months ago #244370 by LNEGmed
Any progress to create this feature into Hikashop?
Best regards,
Christophe.
10 years 3 weeks ago #253918 by gioxd
I am following the discussion for some time because I too have the same problem with SJ Cart Mini Pro. In my opinion the best solution would be to bring up the default cart hikashop as a dropdown form. I tried in every way, but I did not succeed. The next hikashop update you can enter this option? As an example attached
Or can I find other solutions now to bring up the cart module in a drop down menu?
10 years 3 weeks ago #253935 by nicolas
Here are some instructions to do such effect on your own:
www.mtense.com/entry/adding-full-cart-di...-hikashop-mini-carts
www.virgowebdesign.com/our-blog/58-5-awe...hop-e-commerce-store
The next HikaShop update won't have that option as we're working on other things.
10 years 3 weeks ago - 10 years 3 weeks ago #253977 by gioxd
Thanks Nicolas! I tried to follow the guide of virgowebdesign, but in the end I preferred to put a cart minimal, almost like that of Amazon, only with the number of products.
It was not difficult, and perhaps even better than the cart dropdown. Sure, in the graphics I'm a duffer! :D
Last edit: 10 years 3 weeks ago by gioxd.
