- Thank you received: 12
Order status is not changing to "cancelled"
- joshualdouglas
9 years 1 month ago - 9 years 1 month ago #279260
by joshualdouglas
Order status is not changing to "cancelled" was created by joshualdouglas
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.5.38
I have noticed a bug in one of my Hikashop sites. The order status is not changing to "cancelled" when clicking "cancel and return to seller" in the Paypal redirect. The order status remains "Created". This does not happen in my other Hikashop sites.
In the paypal method specific configuration I have:
Invalid status: cancelled
Pending status: pending
Verified status: Confirmed
What could I have done wrong in this site?
Last edit: 9 years 1 month ago by joshualdouglas.
9 years 1 month ago #279262
Replied by nicolas on topic Order status is not changing to "cancelled"
The order status changes to the first ( in time, not in the rows of the listing) status you enabled in the column "cancelled" of the System>Order statuses menu.
- joshualdouglas
9 years 1 month ago #279322
by joshualdouglas
Replied by joshualdouglas on topic Order status is not changing to "cancelled"
The first enabled column is "cancelled" - please see attached.
Is there something else?
Thank you,
J.
Thank you,
J.
9 years 1 month ago #279330
Please deactivate all the statuses in that column. Then, activate "cancelled" first and then "refunded" to make sure that it is the first.
Also, make sure that the "created" status is activated in the "cancellable" column so as to authorize the customer to cancel orders with the "created" order status. Otherwise, it won't do the change.
- joshualdouglas
9 years 1 month ago #279457
by joshualdouglas
I have just tried this. The order status still remains "cancelled".
Thanks,
J.
Thanks,
J.
- joshualdouglas
9 years 1 month ago #279802
by joshualdouglas
Do I need to edit some code?
Thanks,
Josh.
Thanks,
Josh.
9 years 1 month ago #279813
In a previous message you said that the order status is cancelled:
So we thought that the problem was solved.
If you still have a problem, can you provide again a screenshot of the Order statuses listing now that you've modified them ?
www.hikashop.com/forum/orders-management...ancelled.html#279457I have just tried this. The order status still remains "cancelled".
- joshualdouglas
9 years 1 month ago #279874
by joshualdouglas
Apologies, I meant to say "The order status still remains "created".
Please see attached images.
Thanks,
Josh.
Thanks,
Josh.
- Thank you received: 1778
9 years 1 month ago #279918
by Mohamed Thelji
Replied by Mohamed Thelji on topic Order status is not changing to "cancelled"
Hello Josh,
We just tested it on our end and it worked fine, can you give us a link to your website so that we can directly reproduce your issue ?
Thank you.
Thank you.
