- Thank you received: 14229
import problem
11 years 8 months ago #185655
Replied by nicolas on topic import problem
Yes. You can add a product_vendor_id column in the CSV and set the id of the vendor in HikaMarket for each product and that way it will link the imported product with the vendor in HikaMarket.
This of course requires that the vendors are already in HikaMarket.
11 years 8 months ago #185733
by HansIT
Replied by HansIT on topic import problem
YThanx Nicoals,
I know that but is there no other way so that you could import new options and vendors in hikashop instead of first put the vendors in Hikashop?
11 years 8 months ago #185755
by Jerome
Replied by Jerome on topic import problem
I'm sorry but it is not possible for the moment.
I have in the HikaMarket TODO list the task to create an import system for HikaMarket (in the front-end, for the vendors).
One idea behind this development is also to improve the HikaShop import with new idea and new features ; one of the improvements is to allow plugins (or external components) to be plug on the import.
So thanks to that, HikaMarket would be able to access to the import request and handle some specific columns.
Time to create page: 0.147 seconds
