Problem with checkout configuration
15 years 4 months ago #19577 by kasnola
I have the checkout configured to always go to checkout after a product is added to the cart, but nothing happens whenever someone adds a product. You can't tell that a product has been added, and have to refresh the page to see the shopping cart contents. I searched the forum, but didn't locate this problem
15 years 4 months ago #19588 by nicolas
Could you give a link to your shop so that we can see what's going on ?
15 years 4 months ago #19597 by kasnola
Sure, the site is located at lazycitydesigns.com/
15 years 4 months ago #19598 by nicolas
Could you double check the "when a product is added to the cart" option of the checkout tab of the configuration ?
Otherwise, maybe it's related to the fact that you didn't publish the hikashop cart module on your pages. Could you try that ?
If that indeed works, could you try to keep the cart module unpublished and change the code:
hikaModule.innerHTML = result;
{hikaModule.innerHTML = result;}
at the several places where it is in the file administrator/components/com_hikashop/helper/cart.php and see if it helps ?
15 years 3 months ago #21360 by Xsile
Hi there!! I'm having a serious problem!!
I can't checkout. I tested in IE, Firefox and chrome.
at first I had a problem with countries and payment method for each region, I could solve it!!
I already disabled all jQuery and tested again still same problem
it doesn't show me the last step on payment.
I'm leaving you here the website www.oencantodafreiria.com
and a registerd and activated user
user: orapois
pass: orapois
15 years 3 months ago #21367 by nicolas
On your checkout, I can see the shipping address selection view. However, I can't see the shipping method selection. That means that you didn't configure your shipping methods properly. Please check on the FAQ on that page to solve the problem:
www.hikashop.com/support/documentation/i...ins-listing.html#faq
15 years 3 months ago #21405 by Xsile
I'm sorry to say this, but there is only 2 possibilities!!
1st: You didn't used the user and pass I gave you. Cause I'm still having some problems with the emails that was why I gave you those.
Or you didn't understand how to work on it! I'm placing a picture with those things you didn't found image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/Untitled_1-20110716.jpg
15 years 3 months ago #21406 by Xsile
Or you didn't understand how to work on it! I'm placing a picture with those things you didn't found image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/Untitled_1-20110716-2.jpg
15 years 3 months ago #21407 by Xsile
There are no shipping methods for the website, the client doesn't want them
15 years 3 months ago #21418 by nicolas
I got the exact same screen as the screenshot you posted.
The shipping is activated automatically if you have the shipping view in the "checkout workflow" option of the configuration and that you specify a weight for the products (or that the option "Force shipping regardless of weight" is activated).
If you don't want hikashop to require a shipping selection for your products you should either:
1. remove the weight from the products if you set one or deactivate the option 'Force shipping regardless of weight' of the configuration.
2. remove the shipping_ view from the "checkout workflow" option of the configuration.
Time to create page: 0.277 seconds
