US-based site having tax problems
15 years 1 month ago #26113 by syghefish
I have two tax-related issues that I can't seem to figure out. Firstly, tax is being calculated per item instead of per order. For example I have an order of three items which each say:
$4.50 +$0.23 of VAT
Instead of having three 4.50 items totaled up, then taxed. The differences this makes in the total tax is subtle, but still wrong. I am overcharging customers on state tax, which is illegal, so I need to fix that. Secondly, despite having clicked the "Apply Discounts Before Taxes" option, it still takes the tax percentage from the pre-discount amount. Again, because of this I am overcharging on state tax.
Any suggestions? I have HikaShop Essential. Thanks!
15 years 1 month ago #26114 by syghefish
I just tried checking out with the Apply Discounts After Taxes option and nothing changes. I think this option may be broken?
15 years 1 month ago #26128 by nicolas
Taxes are indeed calculated before summing products prices as it is common practice in Europe AFAIK and that it is more logical for users ( some customers will refrain from buying because if they buy 5 items at €5 and they are charged €25.02 they will think that your website is not serious enough ).
If you want to calculate that differently, you can build a product quantity calculation override plugin using the explanation there:
www.hikashop.com/en/support/documentatio...tation.html#override
For the Apply Discounts After Taxes option, I recall that there was indeed a problem with previous versions of HikaShop. Do you have the latest version ?
15 years 1 month ago #26144 by syghefish
I should be, I'm running 1.5.3.
I'm not terribly qualified to create my own override plugin. If it's just a matter of copying a file and changing a line or two of code, then I could handle it, but from the description you linked it seems like quite a bit of work. Do you know of anyone who has already done this that can provide a file for me to download?
15 years 1 month ago #26159 by nicolas
No one has done such plugin yet.
I've made a plugin for you for that but it's not tested so it might not work. Let me know if you get errors.
15 years 1 month ago #26188 by syghefish
Thanks so much! I dropped these files into plugins/hikashop, then navigated on the Joomla back end to Hikashop > System > Configuration > Plugins and it wasn't there. I also tried checking out and it doesn't seem to be implemented. Did I install incorrectly?
Thanks again.
15 years 1 month ago #26201 by nicolas
You need to install that plugin via the joomla installer.
15 years 1 month ago #26202 by syghefish
I tried that as well, but I figured it was the wrong thing to do because I got this error:
JInstaller::install: File '/home/parsonage/parsonagesoap.com/tmp/install_4e824fc86ef49/custom_quantity_weight.php' does not exist.
15 years 1 month ago #26210 by nicolas
Indeed, the xml was not correct. Here is a new package with the xml file corrected.
15 years 1 month ago #26212 by syghefish
Great! That installed correctly, but now no taxes are being charged. Can I move this issue to email? I believe I still have the address.
15 years 1 month ago #26213 by nicolas
I just saw that I mixed the packages I had. Please try with that one
15 years 1 month ago #26301 by syghefish
An error on install:
JInstaller::install: There is already a folder called '/xxx/xxx/xxx.com/plugins/system/custom_quantity_tax.php'. Please initially check whether:
• the Extension is already installed
• the file names in the XML file are spelled correctly
• there are no XML files listed inside the extension.xml file
• all of the files (not including XML files) are correctly listed in the extension.xml file and there are no duplicate entries
• there is an empty folder listed from a previous installation attempt
So I unzipped your zip file and replaced the two files in the plugins/system folder, but that didn't work. Is there something else I need to delete before I install this updated version?
15 years 1 month ago #26314 by nicolas
You should uninstall the plugin before installing it again. Also, make sure that you don't have the files /xxx/xxx/xxx.com/plugins/system/custom_quantity_tax* before installing it. then, you should not have the error when installing via joomla.
You say that it didn't work. What do you mean by that ?
15 years 1 month ago - 15 years 1 month ago #26325 by syghefish
It said the plugin was already installed, even after I deleted the files. The exact error is:
Plugin Install: Plugin "custom_quantity_tax" Already Exists!
Last edit: 15 years 1 month ago by syghefish.
15 years 1 month ago #26340 by nicolas
It's because you still have the plugin registered in the database of joomla. You need to uninstall the plugin not just remove the files.
Anyway, here is a version of the plugin which handles the install over an existing version of the plugin without uninstalling the previous version. That should solve that install problem...
15 years 1 month ago #26362 by syghefish
I emailed you with some more details about the situation. Sorry for the trouble, thanks for the help.
15 years 1 month ago #26364 by nicolas
For everyone else, here is the latest version of that plugin which is working.
14 years 11 months ago #30815 by alansunderland
Is this plugin for all versions - I currently have Hikashop Business and having the same issues of the taxes being slightly off.
many thanks
14 years 11 months ago #30840 by nicolas
Yes, it works for all the versions.
14 years 7 months ago - 14 years 7 months ago #45475 by palmaid
I have a same problem. I dont want that the webshop round the unit tax. I'd like to round only the sum tax.
(Sorry, I wanted to write this here: www.hikashop.com/en/forum/3-bug-report/3...lculation-error.html )
Last edit: 14 years 7 months ago by palmaid.
