Four important questions for basic customization
14 years 8 months ago #43637 by tasag
Good afternoon,
I have some doubts.
1: Backgrounds:
I managed to change the background color of the images of the lists of categories and products, however when I walk into a category remains blank, change the color of the list of products in a category?
2:
Changing the size of product images, I've found how to change the images, but I only have the main image and the size is very small.
3rd.
The paid version comes without the promotional link?
4
How to change the button style checkout?
I want to buy the Pro version, but I want to explore everything.
Thank you.
Porque todo aquele que persevera colherá o fruto doce da vitória.
14 years 8 months ago #43639 by nicolas
1. Could you give a link so that we can see what you did ?
2. Make sure that you do that in the Files tab of the configuration.
3. Yes, you can turn that off with the "show footer" option of the Display tab of the configuration.
4. The buttons style should be in your template's CSS file. You can change the style of the buttons on your website with simple CSS like that:
.button {
color: white !important;
14 years 8 months ago #43642 by tasag
Thank you for your attention, I managed to change the image size of the product was great.
But I find no way to let the background image of the product, the product list by category of another color.
The link is this, I'm auditioning all day.
teste.gruponews.com/index.php/categorias
14 years 8 months ago #43644 by nicolas
Go in the menu Display->Content modules, edit the module with the id 91 and set the background color to what you want.
14 years 8 months ago #43652 by tasag
Wonder, but now how do I change the width of the bottom, the height could ...
Is this the same place?
14 years 8 months ago #43655 by nicolas
What do you mean ?
14 years 8 months ago #43659 by tasag
Sorry the English is Google! lol
Already changed the background color, can change the height but the width background can not, look at the example:
teste.gruponews.com/index.php/categorias/category/12-casamentos
14 years 8 months ago #43661 by nicolas
The width depends on the number of columns option.
14 years 8 months ago #43670 by tasag
I managed to configure. thank you very much
Hello, sorry for the hassle, why when I allow comments on the product the cart and login modules disappear?
14 years 8 months ago #43674 by nicolas
I don't have that problem on your website.
14 years 8 months ago #43681 by tasag
Sorry, it's because I was disabled, but try to see now.
14 years 8 months ago #43684 by nicolas
Please edit the file "form" of the view "vote" via the menu Display->Views for your front end template and change the line:
<input class="button" type="button" value="Send" onClick="hikashop_send_comment();"
<input class="button" type="button" value="Send" onClick="hikashop_send_comment();"/>
The following user(s) said Thank You: tasag
14 years 8 months ago #43687 by tasag
but I can edit within the Hika or i must to change the file and upload via FTP?
14 years 8 months ago #43688 by tasag
Hey!
Found, wonder.
Friend, I am very grateful for your helpfulness.
14 years 8 months ago #43689 by tasag
There is possibility to change the color and shape of the comments area?
14 years 8 months ago #43701 by nicolas
You can do that by editing the CSS of HikaShop via the Display tab of the configuration.
14 years 8 months ago #43711 by tasag
Hello Nicolas,
I spent all day learning how to work with Hikary, all in the test environment.
Now installed in the main domain and I can not save the settings, Hika not let me save saying:
"Your checkout workflow is empty.
Checkout workflow invalid. The modification is ignored. See the documentation for more information on how to configure That option
Entered in valid weight unit. The system put back the default units.
Entered unit dimension in valid. The system put back the default units.
Saved Successfully "
I already checked and everything is as it had done earlier.
What should it be acontencendo?
14 years 8 months ago #43714 by nicolas
That comes from a cookie/cache issue of your browser. Could oyu try with another browser ?
14 years 8 months ago #43719 by tasag
Oh my friend, you were right, I was using Chrome, had already cleared Cache and Cookie and the error still, just going for Firefox that solved the problem.
Thank again.
14 years 8 months ago #43729 by tasag
nicolas wrote: Please edit the file "form" of the view "vote" via the menu Display->Views for your front end template and change the line:
Hello Nicolas,
the first time everything worked, it worked like you said. ex. ( teste.gruponews.com/index.php/produtos/product/1-rosas )
Now when I'm setting up for the official website of the modules disappear again. ex. ( myamarylis.com/index.php/amo-te/product/3-buque-de-teste )
I've done the changes you told me, could help me again?
